shelby uca relocation
Old Sep 23, 2007 | 11:59 PM
project.65's Avatar
project.65
Default RE: shelby uca relocation
I remember Wheel Works quoted me $27 for regular allignment and $107 if it needs shims.[sm=smiley29.gif]
Old Sep 24, 2007 | 12:01 AM
Starfury's Avatar
Starfury
Wow, that's slightly rediculous. I mean, it's difficult...but not that difficult.
Old Sep 24, 2007 | 12:10 PM
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: project.65
That price schedule might be reasonable if you need to get the rear toe corrected on a newer car. In that case, the shim is a tapered piece that requires some disassembly to install.
Shims for front end alignment normally are flat U-shaped pieces that you can slip in once the control arm cross shaft bolts are loosened.
Norm
Old Sep 24, 2007 | 12:54 PM
Decurion's Avatar
Decurion
ORIGINAL: true66gt
no i know wtf a shim is. it sounded like decurion said i have to figure out the shims myself or ill get charged for the shop to do it. so do i need any shims with the relocation or not? should i leave the shims that are already there or should i ditch em?
What I meant was before you put the shims back in, check to make sure the control arms clear in a worst case scenario. My control arms had plenty of room when I installed them after the shelby drop (they happened to have a big stack of shims before), but when the tech went to align it, he had to take out a bunch of shims which pushed the control arm into the shock tower. Like I say though, you may not even have to clearance anything.
Old Sep 24, 2007 | 01:01 PM
ky's Avatar
ky
America ftw
why are we talking about shims? everyone knows what a shim is or they shouldnt be dealing with cars then. anyway, if i make my own template, how perfectly do the holes have to be drilled? in other words, if theyre a 1/16th or so of an inch off is it gonna matter? or do they have to be DEAD ON PERFECT? i just dont want to screw it up and have to buy new shock towers.
Old Sep 24, 2007 | 02:37 PM
Starfury's Avatar
Starfury
As perfectly as possible, and I'd try to get closer than 1/16". This is partly why templates make life easier.
Old Sep 24, 2007 | 03:47 PM
bluovalguy's Avatar
bluovalguy
ORIGINAL: true66gt
Thats kind of aodd statement given the nature of this site.
Old Sep 24, 2007 | 06:55 PM
gothand's Avatar
gothand
ORIGINAL: Starfury
... and a center punch and a small pilot hole.
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Bokeo
Oct 10, 2015 08:28 PM
UrS4
Oct 3, 2015 06:23 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
