GM 1 Wire Alternator
So I am going to go to the GM one wire alternator, is there a year that will the early model mustang, or is there a kit that I need to purchase to make one of these fit?? Thanks for any help
67 Coupe
351 Windsor
67 Coupe
351 Windsor
http://store.summitracing.com/egnsea...=sku&RC=10
Try one of the top 4 on this list, as far as I can tell they are a direct bolt on...
http://store.summitracing.com/partde...p;autoview=sku
We bought this one, ^ it has worked perfectly for a whole 75 miles or so,
charges 13.9 V at idle with undersized pulleys, and 14.1 V at speed.
It will be a direct bolt on with the possible exception of the alternator
spacer, I don't know for sure because I had to start mostly from scratch
with my mounting.
with my mounting.
I bought SUM-810302 and a couple things that I had issues with when installing were; the charging stud was resting on the block when mounted with the stock lower bracket and belt. So I extended the lower bracket 1.5 inches on the non slotted side with a slight upward angle to clear the bigger Alternator fan, then I added a belt that was an inch longer. After that I cut the extra length off of the charging stud. Now I have plenty of block clearance and room for belt adjustment.
[IMG]local://upfiles/65951/D8025E6E263D4FCAB7C20C906CBBF0A9.jpg[/IMG]
[IMG]local://upfiles/65951/4066C0C22F434D4EBF5EF08FC91B6D7A.jpg[/IMG]
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
