Not a ford Radiator?
Old Sep 24, 2007 | 03:05 PM
kaiser18's Avatar
kaiser18
Default Not a ford Radiator?
I think my radiator isnt the proper model for my mustang, in fact I dont think its even a ford product. I have been told that a rad from a 69 should be wider and not as tall. Infact I think there is very little space between my radcap and the hood when closed. Does anyone have any info on the radiators that belong to the 69s, or ones that I should concider buying.
[IMG]local://upfiles/71401/91EECA6AD82540CC834776D5FEAE6F84.jpg[/IMG]
Old Sep 24, 2007 | 03:08 PM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: Radiator to small?
looks like the stock 2 row to me, but i would go with something a little bigger, a 3 or 4 row. make sure you check the clearance to the fan before buying a new radiator. you can just get a smaller spacer for the fan if you need to,but its tedious to do[&:]
Old Sep 24, 2007 | 03:11 PM
kaiser18's Avatar
kaiser18
ORIGINAL: Mustangdemon67
Yup its a two row, Its in pritty bad shape too. While the engine is running, I can place my hand on ares of the rad and its cold!, while other spots are blazing hot. So i need to replace it soon.
Old Sep 24, 2007 | 03:56 PM
Mustangdemon67
when you replace it, get that radiator filter that goes in the hose, its like 45$ but its worth it.
Old Sep 24, 2007 | 04:10 PM
dodgestang's Avatar
dodgestang
Have you consider simply flushing the system?
Are you having an overheating problem now?
Old Sep 24, 2007 | 04:38 PM
kaiser18's Avatar
kaiser18
ORIGINAL: dodgestang
Its was running hot untill I replaced my waterpump. Now it sits on the halfway mark on the gauge when idling. I was thinking of getting the radiator flushed out but if indeed this radiator is non ford or was ment for a smaller engine, i would like to replace it.
squishbang
Jan 26, 2016 04:58 PM
Gun Jam
Oct 4, 2015 12:10 AM
DrunknRuckus
Aug 23, 2015 10:05 AM
inyadreems
Aug 21, 2015 09:10 AM
jdphillips73
Aug 16, 2015 04:34 PM
