posi traction??
Old Sep 24, 2007 | 03:59 PM
roneades's Avatar
roneades
Default posi traction??
I have a 70 mach 1 351 cleveland with a FMX tranmission and posi rear end. When I pull out slow with the wheels turned the entire car feels like it has shifted to the side. It feels like someone has just pushed the body over. What is the cause and what is the cure?
Thanks - Ron
Old Sep 24, 2007 | 04:03 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: posi traction??
ORIGINAL: roneades
Thanks - Ron
Try a fluid change first, if that doesn't work, you'll probably have to rebuild the rear end and take out some of the clutches. Too many will make it act like a full locker rear end (both wheels rotate at the same speed in turns)
Old Sep 24, 2007 | 04:09 PM
JMD's Avatar
JMD
+1 on the gear oil, and don't forget the friction modifier additive.
Old Sep 24, 2007 | 04:12 PM
67 evil eleanor's Avatar
67 evil eleanor
+1 on the fluid change. Also after you do that, you may try doing about 30 or 40 figure 8's and see if that loosens it up any.
Old Sep 24, 2007 | 04:54 PM
valley firearms's Avatar
valley firearms
Use the royal purple. It already has the additive. Does it make any noises when you turn?
[align=left] [/align]
Old Sep 24, 2007 | 05:04 PM
andrewmp6's Avatar
andrewmp6
is it a new posi or was it in the car when you bought it a locker will act like that.
Old Sep 24, 2007 | 06:35 PM
deadcarnahans's Avatar
deadcarnahans
Go to the Chevey dealer and get some friction modifier or get rid of the posi and install a Ford traction lok unit.
Old Sep 24, 2007 | 06:38 PM
gothand's Avatar
gothand
ORIGINAL: deadcarnahans
[sm=icon_stickpoke.gif]
Old Sep 24, 2007 | 07:32 PM
ldollar's Avatar
ldollar
I ♥ Acer
I was wondering if Daze would chip in here... [sm=yikesomg.gif]
ChampInSD
Oct 2, 2015 04:55 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
Sep 8, 2015 11:50 AM
iculookin
Sep 2, 2015 12:34 PM
