Engine Swap ?
Old Sep 25, 2007 | 11:06 AM
Trmachuno's Avatar
Trmachuno
Default Engine Swap ?
Just wondering how much would an auto/performance shop charge to do an engine sway? I see all these cheap crate engines(308's pushing 400hp+ for $3k shipped)on ebay and my dad and I r thinking of getting a project car for next yr and if it has a lot of miles on the engine, doing a swap. probably getting a 5.0 or older mustang. Just want to know some estimates and see what it will run. And also if u can tell me how much hp each of the transmission could take(5spd stick) stock and is there a way to make them stronger w/o taking them out or putting in a new one?
Thanks In Advance
Old Sep 25, 2007 | 11:43 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Engine Swap ?
for a performance shop its gonna cost a pretty penny
tranny specs
t-45 300hp
t-5 400
t-56 550-600
i think thats pretty close someone will tell me/ you diffrent if its not.
Old Sep 25, 2007 | 12:08 PM
Trmachuno's Avatar
Trmachuno
Thanx!
Old Sep 25, 2007 | 12:25 PM
crunchyskippy's Avatar
crunchyskippy
ORIGINAL: SteelStang05
Your mileage may vary, but I'm guessing a shop that knows what they're doing can probably complete the swap in ~10 hours. Maybe more, maybe a lotless. So lets say they charge $80 an hour, that's $800. Then there's always "extra" stuff you didn't realize you needed...maybe some hoses, fuel pump, gaskets, antifreeze, heck even fresh oil. I bet your into another $200 before you know it.
I'd set aside $1000 for the engine swap if you have someone else perform it. Keep in mind that my guess assumes that you re-use as much as you can (including intake and carb).
The best thing to keep in mind is just replace things as you needto (read: when you can afford it). Otherwise it is very overwhelming, for me at least.
Good luck.
Old Sep 25, 2007 | 01:05 PM
USMCrebel's Avatar
USMCrebel
i got quoted by the cheap guy in Alabama for 1200, so i did it myself, lots of problems so they will charge you for those as well.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
