Steering problems
Old Feb 19, 2005 | 12:42 AM
chech626's Avatar
chech626
Default Steering problems
Just bought a new steering box and i am having some problems. once i installed it and took it for a test run the steering was real hard turning right but easy turning left. If anyone could help it would be great
Thanx
Old May 26, 2005 | 01:18 AM
diverdown's Avatar
diverdown
Default RE: Steering problems
I guess nobody here knows how to fix the problem
Old May 26, 2005 | 04:25 AM
Soaring's Avatar
Soaring
I ♥ Acer
Need some more information. What year? Manual or power?
Old May 26, 2005 | 10:46 AM
diverdown's Avatar
diverdown
the car I am working on is a 69 Mach 1.
Old May 26, 2005 | 11:37 AM
1970 mach1's Avatar
1970 mach1
Power steering or not ?
Old May 26, 2005 | 11:51 AM
1970 mach1's Avatar
1970 mach1
Sorry I just read your first post it is power with assist. This sounds like the power assist unit has a right side bad valve. I would try switching the left side pressure line with the right side pressure line and see if problem reverses. If this is a fact you have a bad assisting unit. I'm sure that you have checked the right side pressure line to make sure it has no blockage. Also make sure the assist unit shaft is centered evenly for both directions. It is not the power steering unit it just supplies the pressure for the assist unit.
Old May 26, 2005 | 11:54 AM
1970 mach1's Avatar
1970 mach1
The worm gear could also be adjusted to tight being that it is new. How much slack do you have in steering wheel. Do you have a little play left and right or no play at all ?
Old May 26, 2005 | 03:19 PM
diverdown's Avatar
diverdown
Hello, Thanks for the reply, It has very little play in the steering. I tried crossing the line and the wheel took a hard right. so I am in the process of chanding the control valve, so for now I am off to work I go. I will keep you posted.
Thanks Larry
Old May 26, 2005 | 08:56 PM
diverdown's Avatar
diverdown
It was the power steering control valve. I put the old one back in and it works like a charm.
Thanks 1970 mach1 for your help and responding to this post. Larry
Old May 26, 2005 | 09:31 PM
1970 mach1's Avatar
1970 mach1
Well thank you Larry and your wecome I am glad that I could help.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
uberstang1
Sep 20, 2015 06:42 PM
rksnow1
Sep 14, 2015 08:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 8, 2015 11:50 AM
