Disc brake swap
Old Sep 29, 2007 | 01:55 PM
Mustang Dad's Avatar
Mustang Dad
Default Disc brake swap
Can anyone tell me which of the Ford or Mercury cars make good donors for the disc brake swap? I cant find a good list anywhere...some say the Granada, some the Fairlane, others the Monarch. Which is the best, and can parts be swapped between the many different doners.....Granada and Fairlane........Fairlane and Monarch........Granada and Monarch?
Old Sep 29, 2007 | 03:56 PM
Matt302's Avatar
Matt302
Default RE: Disc brake swap
I got a 9in. rear end out of a Lincoln Versailles, which already has disk brakes. It takes a little modification but you get disk brakes and a stronger rear end. For the front I got four piston Kelsey-Hayes disk brakes kit from a place called ABS in Orange, CA for $700.00
Old Sep 29, 2007 | 04:06 PM
67 evil eleanor's Avatar
67 evil eleanor
I have harvested a couple from Granada's. I had to change the tie rod ends as the taper is different. As far as the rear, the Lincoln Versalles will work. Also I have modified a couple of rear sets off 2000 Ford Explorers to fit the 9" housings.
Old Sep 29, 2007 | 05:16 PM
JamesW's Avatar
JamesW
Granadas and Monarchs are the same thing. One is Ford and one is Mercury.
Here's some info:
http://midnightdsigns.com/james/Disc%20Brakes.htm
Old Sep 29, 2007 | 09:01 PM
degins's Avatar
degins
For Granada type front brake swap:
74-77 Maverick/Comet
75-80 Granada/Monarch
Old Sep 29, 2007 | 09:22 PM
JamesW's Avatar
JamesW
Recommend going with Dennis' CSRP setup. Finding Granadas/Monarch/Versailles sets in wrecking yards are haystack needles, will cost you almost as Dennis' set once you've replaced all the calipers, hoses, rotors, etc... and his setup has been corrected for the bumpsteer condition.
Now if you have 5 lug drums on the front... I'd like to talk buying them from you...
Old Sep 30, 2007 | 12:27 AM
RolandT3Speed's Avatar
RolandT3Speed
I did the Granda swap.
'76 spindles and '80 discs.
Even with buying new calipers, tie rod ends, bearings, rotors turned, and pads the whole cost was under $400
Make sure you get the dust shields.
Old Sep 30, 2007 | 09:01 AM
andrewmp6's Avatar
andrewmp6
the Granada swap is nice but you can get better brakes cheaper http://www.mustangsteve.com/cobrabrakes.html the cobra brakes are pbr the same thing baer brakes are but cheaper.
Old Sep 30, 2007 | 09:11 AM
RolandT3Speed
ORIGINAL: andrewmp6
Omg! That's awesome! Pity that wasn't available way back when I did my swap.
However, I just might look into that for the rear!
Old Sep 30, 2007 | 09:23 AM
JamesW's Avatar
JamesW
Steve's answer is great for those going with the 17" wheels. It really fits nice.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
maestro1024
Sep 21, 2015 02:40 PM
uberstang1
Sep 21, 2015 09:04 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
