302 Build up
Old Sep 30, 2007 | 01:20 PM
StangDB's Avatar
StangDB
Default 302 Build up
Anyone have a link or knowlage on piston rings, im putting them on and want to double check before hand.
Old Sep 30, 2007 | 01:29 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: 302 Build up
what are you looking for on knowledge their are several kinds high compression, replacement, low compression kinds for Forced induction.
Can you be a bit more specific?
Old Sep 30, 2007 | 01:36 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Best thing is to read the paperwork that came with the piston rings. But, as asked, what specifically do you want to know?
Don't line up the gaps on the oil ring set. I set mine about 120* apart. The other gaps don't matter as the rings rotate a bit while in the bore during the stroke, so the gaps will line up for some time on the compression rings.
bradleyb
Nov 27, 2015 07:50 PM
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jaiidutch
Sep 14, 2015 10:29 AM
