Firing order
Old Oct 18, 2007 | 11:48 AM
kalli's Avatar
kalli
Default RE: Firing order
great you're rolling again.
seems like crunchyskippy had it dead straight in first response
Assuming you tried "15426378", you could always try "13726548" - which is the standard for the 351.
Refresh us of your engine...did you replace your cam? What year is your engine?
Lastly, I think I may remember that there was an alternate firing order for the 302...was it on the hi-po maybe? I'll have to check my books when I get home for you.
naturally the spark needs to fire when:
a) the piston is near top position
b) both valves (intake/exhaust) are closed.
A cam tells the valves when to open and how long, but it has no influence on the pistons whatsoever.
In a full cycle the piston is up twice. once for work (spark) and once for exhaust (just pushed out old gas from cylinder).
So it might well be that when in one order the piston is exhausting in the other firing order the piston waits for the spark then your mechanic is dead on in saying: it's the cam.
You can see when comparing the orders under each other that they're the same for the 1st, 4th, 5th and 8th fire the other 4 are interchanged
15426378
13726548
just my 2 cents ..... i don't know ... I just assume. That said: if the fire order was different before putting the cam in place,m then yes. ya. twas the cam
Kalli
Old Oct 18, 2007 | 12:00 PM
THUMPIN455's Avatar
THUMPIN455
ORIGINAL: boogerschnot
ORIGINAL: TexasAxMan
It doesn't matter which way the rotor points, only that the cap post it points to is where you hook up the number 1 wire. You can't remove and reset your distributor 1 tooth off, the oil pump drive would not line up (unless you turned it too). If the distributor is in and the oil pump drive is properly connected, get the engine to TDC on the compression stroke of #1, note where the rotor is pointing (which post of the cap) and start there.
I was just saying that if the dizzy was 180 out, he could easily just point the rotor in the oposite direction that it was pointing by pulling it up instead of finding tdc and then spining the rotor and putting it back in on #1.. Only if you actually had it timed to the correct exhaust stroke..Whatever you want to do though..
both are right, but why not move wires around since you already have the distributor in the engine? Find top dead center #1 cylinder, put the plug wire on that post. Then follow the firing order. That is how I do every engine I build, that way I am sure it is right. Yanking the distributor and not movin any wires is only more work, since you will ned up pulling it a bunch and fighting with the oil pump drive each time, then still moving the wires.
Just $.02 from someone who got paid by how fast they got the thing done..
Old Oct 18, 2007 | 12:08 PM
67mustang302's Avatar
67mustang302
Ford changed to the 351W firing order on the 302's in order to revise main bearing load, or at least according to the engineers. Supposedly the 351 firing order stresses the main webs slightly less
Old Oct 18, 2007 | 12:52 PM
TexasAxMan's Avatar
TexasAxMan
I saw on HorsepowerTV that swapping #4 and #7 in the Chevy firing order made more HP, of course theyused a cam made for the swap.
So they went from 1-8-4-3-6-5-7-2 to 1-8-7-3-6-5-4-2.
It's also interesting to note that Chevy and Ford use the same firing order for small blocks, if you number the cylinders the same way.
Old Oct 18, 2007 | 02:34 PM
boogerschnot's Avatar
boogerschnot
Hey,, its KALLI,, welcome back man,, havent seen you around in a while..
Old Oct 19, 2007 | 08:29 AM
kalli's Avatar
kalli
thanks man,
can't keep up with the amount of posts per day ... it's mad and I onlky get to check during work
but yes, I like to look at some of the posts, so I don't have a too bad conscience when posting my own problems ;-)
Kalli
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Drastang
Sep 30, 2015 03:48 AM
GLOCKer
Sep 28, 2015 07:36 AM
