carbs?
Old Oct 6, 2007 | 08:48 PM
free70coupe's Avatar
free70coupe
Default carbs?
I have a 70 Mustang coupe with 302 2v engine whichI got for free a few weeks ago. It has what looks like a 4 brl carb but has only 2 brl's! Did Ford use 4 brl intake manifolds and put 2 brl carbs on them? I am totally new to the Ford world and was hoping someone knew without me having to take the carb off and looking myself. Thanks.
Old Oct 6, 2007 | 08:54 PM
valley firearms's Avatar
valley firearms
Default RE: carbs?
Maybe the PO put a 2 bbl adapter onto a 4 bbl manifold.
[align=left] [/align]
Old Oct 6, 2007 | 09:18 PM
free70coupe
Default RE: carbs?
I know the carb was replaced cause it has a sticker on it says reman 1991 but car has 83,000 original miles and has not been modified as far as I know. I got it from the owners who have had it since 1979. I just never seen a 2 brl carb that is exactly like a 4brl carb but no secondaries. I am used to GM's so this is something I never seen before.
Old Oct 6, 2007 | 09:25 PM
valley firearms
Default RE: carbs?
well, a 2 bbl carb is half of a 4 bbl carb[8D]
Old Oct 6, 2007 | 09:31 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: carbs?
Holley makes a 2v that is 1/2 a 4v. The Ford/Autolite piece is different.
Old Oct 6, 2007 | 09:40 PM
free70coupe
Default RE: carbs?
I know a 2brl is half of a 4 brl but usually there isnt a 4brl sized carb with only 2 brl'sso I thought maybe Ford used 4 brl intakes on v-8 cars and put 2 brl carbs on that look like 4 brl's with blank secondaries.I just dont know with GM's I've dealt with a 2 brl is a different looking carb than a 4 brl.I guess I better take the carb off and check it out. I was hoping someone knew so I wouldnt have to go through the trouble.
Old Oct 8, 2007 | 06:53 AM
73 Sportroof's Avatar
73 Sportroof
Default RE: carbs?
I think free70coupe is talking about the fact that the motorcraft 2bbl uses the same air cleaner as a 4bbl. The GM 2bbl is smaller on the top than a 4bbl, to use a 4bbl air cleaner you need an adapter to bring it out to 5 1/4".
You don't need to remove it. It is a 2bbl.
Old Oct 8, 2007 | 02:43 PM
Starfury's Avatar
Starfury
Default RE: carbs?
Autolite's 2100 2V carb is essentially half of a 4100 4V carb, and yes, the air cleaner mounting surface is the same diameter.
Old Oct 8, 2007 | 02:54 PM
jlg2002's Avatar
jlg2002
Default RE: carbs?
ORIGINAL: free70coupe
No, ford did not use 2bbl on 4bbl manifolds.
Old Oct 8, 2007 | 02:59 PM
free70coupe
Default RE: carbs?
Great! Thanks for all the responses. Now is it worth getting a 4brl intake and 4brl carb? For the money is the increase in horsepower worth the cost? Engine has low miles so I dont want to do an entire rebuild maybe just simple bolt on improvements?
