QUESTIONS GALOR.
1) whats a good suspension for a 1970 coupe. i need the whole 9-yard system (leafs, springs, export bar, sway bars, ext...)
2) im in a budget for building my suspension, brakes and new tires and rims. so where can i find a disc brake conversion for the front, and or should i also build the back? or just rebuild the drums? any good brand or site to go to for this that yall have used and had no problems with?
3) what size torque thrust can i go with a 70 coupe for rear? 17 x ?
brakes id look at http://www.mustangsteve.com/cobrabrakes.html everything else http://www.opentrackerracingproducts.com/products/ yes opentracker is more money but its built better. or rebuild your a arms with better bushings and ball joints get his roller spring perches and polyuethane insulator pad and baer tracker tie rod ends are a must. also a monte carlo bar and export brace are well worth the money.the reason i say mustangsteve is the cobra brakes are pbr same thing baer brakes are and alot cheaper.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
