frame rail replacement
Old Oct 7, 2007 | 10:38 AM
1967coupe's Avatar
1967coupe
Default frame rail replacement
Has anyone had any experience replacing front frame rails? I had to remove most of the front of the car in front of the firewall. I bought the 1967 shop manual but chassis dimensions are all wrong in the manual so I can't get the frame rails lines up of check the res of the frame alignment.
Does anyone have any suggestions or had problems with the mauals accuaracy?
Old Oct 7, 2007 | 11:09 AM
valley firearms's Avatar
valley firearms
Default RE: frame rail replacement
Maybe the manual is correct and your car has been in an accident in the past. How far off are the dimensions?
[align=left] [/align]
Old Oct 7, 2007 | 08:47 PM
plainsman1876's Avatar
plainsman1876
Something doen't sound right
Old Oct 8, 2007 | 10:29 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
+1
the shock towers might have fallen in, but the frame rails? its def been in a wreck if its off that bad, and if thats the case just take it to the frame shop, they should be able to help some.
Old Oct 9, 2007 | 09:02 PM
1967coupe's Avatar
1967coupe
I did some more measuring and got the dimensions to come out right the second time.The right frame rail is off by only about 1/4 inch and I have no reference points to measure the left one since most of the points to make my baseline are parts I have taken off to replace. Called a frame shop and got a quote of $800-1000 to check and weld the rail on. Might be worth it.
Wouldn't surprise me if it was in a wreck, it's been badly abused but it is restorable.
Old Oct 9, 2007 | 10:16 PM
plainsman1876
Thats great it is well worth it to have it done right the frist time
5.0muscle
Jan 11, 2016 01:17 PM
Oak
Sep 14, 2015 03:08 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
