Comp Cam
Old Oct 8, 2007 | 02:15 AM
1970coupe's Avatar
1970coupe
Default Comp Cam
when looking at a cams rpm range the best for torque is the lowest correct? so if im looking at a 1000-5500 rpm range is that pretty torquey? also does the lopeyness of the cam change when you go higher or lower in rpms?
Old Oct 8, 2007 | 03:01 PM
Starfury's Avatar
Starfury
Default RE: Comp Cam
Yes, yes, and higher Which cam are you looking at?
Old Oct 8, 2007 | 03:07 PM
jlg2002's Avatar
jlg2002
+1 with starfury, and you have to start chnging valve train gear with a big cam. Be careful.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
