engine painting
Old Oct 9, 2007 | 08:12 PM
70coupe's Avatar
70coupe
Default engine painting
has anyone painted there engine themselves? i am having my engine rebuilt and while the block and heads are at the machine shop i have been sand blasting and painnting all of my other parts so they will be ready for reassembly my question is for anyone thats done this or knows about it how many coats of paint are ok for each part ive biin putting 2 coats on everything its the duplicolor high heat paint. is this right or should i use more coats or what i would like it to last for a while. thanks eveyrone.
Old Oct 9, 2007 | 08:27 PM
Starfury's Avatar
Starfury
Default RE: engine painting
I painted my 331 before I dropped it in. I think I used 3 rattle cans of Plasti-Kote Old Ford Blue. Can't recall exactly how many coats, maybe 2 or 3?
Old Oct 9, 2007 | 08:38 PM
70coupe's Avatar
70coupe
sweet thanks for the info i would paint the whole thing all together but im doing different color contrasts with black and deep ford blue so everything has to be painted seperately not soure how it will come out but if i dont like it once its together ill just paind the whole thing one color...thanks again for the info
Old Oct 9, 2007 | 09:13 PM
shr's Avatar
shr
also single stage paint works well! but its harder and more expensive to spray out
Old Oct 9, 2007 | 09:18 PM
RolandT3Speed's Avatar
RolandT3Speed
ORIGINAL: Starfury
Heh, same here. 10 years later and the paint still looks good!
Just make sure to clean the block before you paint.
I used acetone. Wear gloves.
Old Oct 9, 2007 | 10:13 PM
plainsman1876's Avatar
plainsman1876
I painted mine 3 differnt colors , New Ford blue , Black , and Gold , I put 4-5 coats of primer , 4-5 coats of the colors , it looks great
Old Oct 9, 2007 | 11:32 PM
JMD's Avatar
JMD
IMO just put enough paint to cover everything the way you want it covered. If it looks good after 2 coats stop. Applying thicker paint than needed to cover well serves no purpose other than to promote cracking, hardening, and peeling.
The thinner the better.
Old Oct 10, 2007 | 10:21 AM
boogerschnot's Avatar
boogerschnot
ORIGINAL: JMD
True,, Too much paint will just crack and fall off.. also, I learned this from the engine shop when I painted my motor: Finger some Petroleum Jelly onto your new freeze plugs before you spray and once the paint is dry wipe out your freeze plugs,, the paint wont stick and they will pretty and shiny for ever!!! I used the old ford darkblue hi temp stuff from kragen and it looks exactly what I wanted it to.. Now I just need new valve covers and it will be sweet! OH,, and I didnt use even half of a can on my block, I dont know how someone could use 2 or 3 cans, thats a lot of paint!
[IMG]local://upfiles/62217/DC8868A9A92B4E2C8254BE2FB32200D9.jpg[/IMG]
Old Oct 10, 2007 | 01:31 PM
Jaded's Avatar
Jaded
ORIGINAL: JMD
+1
I've painted all my blocks myself, including one in bright yellow, with polished or silver hightemp paint. Clean the block, I use degreaser and a stiff brush, tape it off (the vaseline is an old army trick, it works), and lay down some paint.
I also paint the bolt heads by poking them through cardboard and putting a light coat on them.
Old Oct 10, 2007 | 01:49 PM
Starfury's Avatar
Starfury
ORIGINAL: boogerschnot
I painted my block and heads as a unit, and also painted the water pump and timing cover to match. It was definitely more than one can, and I layed it down with multiple light passes to get even coverage without dripping, so there was probably a fair amount of waste. I want to say 2 cans, I just can't remember exactly.
