carb size help?
Old Oct 11, 2007 | 10:28 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: carb size help?
Reman'd carbs. You're likely throwing good money after bad with any used carb that you haven't seen run, and will wind up spending this amount anyway.
EDIT: I wouldn't go below a 650, 700 or 750 would be better.
Old Oct 11, 2007 | 10:35 PM
390bigblock1's Avatar
390bigblock1
the guy said he would put it on his car so i could see it run but i dont have that kind of money right now i need a carb this weekend
Old Oct 12, 2007 | 12:03 AM
390bigblock1
i found a 600cfm 1 from my freinds shop thast used and rebuilt is 600 cfm ok?
Old Oct 12, 2007 | 12:06 AM
69stang390's Avatar
69stang390
you need atleast a 650.
Old Oct 12, 2007 | 12:08 AM
390bigblock1
really i have all my performance parts out of the 390 so its basicly stock right now with a cast iron intake
Old Oct 12, 2007 | 09:01 AM
69FECoupe's Avatar
69FECoupe
A 600 w/vac. secondaries will work just fine. I downsized from a 750 to a 600 on my 69 390 and it worked out great. And that was with headers, an intake and a 428 CJ cam. It became much more street friendly. Don't forget, the vast majority of 390's were produced with 2bbl Autolites.
Daze's Avatar
Daze
here is the mathamitacal formula for a close size
CI X Max RPM/ 3456 =
(390 X 6000)/ 3456 = 677.08333 or in the real worl 675
The autolite 4100 carbs Ford put on these motors were 600 CFM or at least the one sitting inmy gasrage off of a 61 390 is
Old Oct 12, 2007 | 11:19 AM
69stang390's Avatar
69stang390
I wouldnt go less than a 650.....but its your motor.
Old Oct 12, 2007 | 11:45 AM
valley firearms's Avatar
valley firearms
Look on Craigslist everyday. Or put a WTB of Craigslist asking for a carburetor. If you had to rebuild it go to your local parts house and pay $40-$50 for a rebuild kit. Make sure you soak the carb and blow the passages out with air. It might be a learning experience.
[align=left] [/align]
Old Oct 12, 2007 | 01:09 PM
TexasAxMan's Avatar
TexasAxMan
I recommend every auto enthusiast rebuild a carb. I actually find it enjoyable. It was one of the first things I learned to do on cars, back when I was about 13. Second thing wasn't so enjoyable, replacing the water pump (4 times because of bad ones) on my brothers '76 (?) Mustang II with a v6, that sucked.
