carb size help?
Old Oct 12, 2007 | 09:41 PM
  #21
my77stang's Avatar
my77stang
Default RE: carb size help?
holley 390
Old Oct 13, 2007 | 12:26 PM
  #22
Colorado_Mustang's Avatar
Colorado_Mustang
Of course a smaller carb will let the engine run. You will lose mid/upper range performance due to a lack of air flow, and can significantly alter the fuel/air ratio. It will most likely lean out, which you really don't want at higher RPM's.
My 390 is a factory HiPo with the cast iron intake. It has no problem hitting 6k RPM at mile high elevations. Don't let the cast iron intake fool you, it may not be as good as the stuff now, but it will let that 390 turn very hard.
Demodulates
Sep 18, 2015 11:14 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
