Types of Fluids
Old Oct 12, 2007 | 08:03 AM
Erks Eagles's Avatar
Erks Eagles
Default Types of Fluids
What type of Oil, Transmission fluid and brake fluid do you guys recommend using in a '65 with a 289 HiPo?
Thanks
Old Oct 12, 2007 | 09:42 AM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: Types of Fluids
this is what i use in my 289 C4
oil - 10-30w
trans- Type F
brake fluid- DOT 8
Old Oct 12, 2007 | 10:40 AM
blue66mustang's Avatar
blue66mustang
+1
Old Oct 12, 2007 | 09:42 PM
my77stang's Avatar
my77stang
10w40
dexy mercy 3
dot 3
Old Oct 12, 2007 | 11:41 PM
dgulian's Avatar
dgulian
I have switched to Shell Rotella T. The new oils do not have the higher rate of additives that lube a flat tappet cam.Rotella still has them. There is a rise in lobe failure with the older cars. check HotRod.com and see if the article is still there.
Old Oct 13, 2007 | 02:45 AM
69stang390's Avatar
69stang390
ORIGINAL: dgulian
+1
Rotella is also what i use, but if i remember right, valvoline and dexron also have a good one. I think there labeled "for offroad use only".
Old Oct 13, 2007 | 12:22 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Use synthetics throughout. Your cam will not wear out if it's properly broken in. The issue is with the initial break-in.
Old Oct 13, 2007 | 02:29 PM
69stang390's Avatar
69stang390
Myabe on paper, but if you use synthetics in a big block, your asking for trouble.
Old Oct 13, 2007 | 02:50 PM
dgulian's Avatar
dgulian
The oil like from crude oil has had the additves changed to meet the higher warrenty requirements on the emissions. The ones they have cut way back on fowl the converter. I guess that could be why the manufactures have gone to roller lifters maybe................
Old Oct 13, 2007 | 03:52 PM
Colorado_Mustang
That's why my big-blocks last so long...I don't believe the myths. Synthetics outperform every conventional oil in every way, shape, and form. Oil doesn't know how large your engine is, only the material the engine is made from and the oil passage clearances.
ORIGINAL: 69stang390
