Weird problem ????
Old Oct 16, 2007 | 01:24 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Weird problem ????
oooo, i just thought of something else, make sure your vaccuum tube is hooked up. i had that problem on my c4!
Old Oct 16, 2007 | 04:33 PM
THUMPIN455's Avatar
THUMPIN455
If you happen to be in Michigan or Wisconsin, you could come up and I will show you how to rebuild it..
Old Oct 16, 2007 | 04:39 PM
Hawkins 812's Avatar
Hawkins 812
I reside right below you in Indiana...maybe we can work something out ?
Old Oct 16, 2007 | 04:45 PM
boogerschnot's Avatar
boogerschnot
Maybe you could just try changing the tranny fluid and see if you have something nasty sitting in the pan/filter. Worth a try.. Othere than that,, why type of Torque converter do you have?? Whats the stall? And you say it goes just fine after it warms up right??
Old Oct 16, 2007 | 05:21 PM
Hawkins 812
ORIGINAL: boogerschnot
Im going to check the fluid tomorrow.Itwas changed about two weeks ago, but i plan on changing it regardless as long as its still topped off.
c6 Auto with stock TC (16 or 1800 stall i believe)
This is why im labeling it, "weird";
I'll start it up, back it out, and it will drive PERFECT until the first stop. What i mean by that is this ;
The other day, instead of going the normal route, i just kept driving around my house edition w/o completely stopping and it drives BEAUTIFULLY....but as soon as i make that FIRST stop, i have to rev it up past 2500 RPM to get her to go ... then she is fine after that..................
[sm=dontgetit.gif] [sm=wtf.gif] [sm=WTFsgign.gif]
Old Oct 16, 2007 | 07:21 PM
Dancin52's Avatar
Dancin52
I'd check the modulator valve on the tranny, I've been told if you pull the tube off and there is tranny fluid (a drip) it is faulty and needs to be replaced. Also make sure there are no leaks in the line.
Old Oct 17, 2007 | 12:01 AM
boogerschnot
Are you sure its shifting back into first after that first stop?? IF you were in second it would take a bit more RPM to get her going.. Have you noticed if it shifts after that from first to second and then to third or if its maybe just pulling out in second? That would be wierd,, or even if it was in third.. Count the number of shifts after the next time it does that to you..
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
