custom bezel
Old Oct 15, 2007 | 09:30 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: custom bezel
could you go into more detail? on the dremel
Old Oct 15, 2007 | 10:09 PM
Starfury's Avatar
Starfury
Die grinder + carbide bit + time = larger than normal hole
The clock hole is easier to grind out because it actually starts as a hole, unlike all the other spots on the housing which have solid backs.
Old Oct 15, 2007 | 10:43 PM
USMCrebel's Avatar
USMCrebel
lol well no ****.....
Old Oct 15, 2007 | 10:49 PM
Starfury's Avatar
Starfury
lol Well, what other details do you want? It's not really a science. You just put a hole where there isn't one, and try to make it exactly whatever size it needs to be to fit the gauge. I had it easy with the tach; there are already screw holes for the clock, so I just jammed the tach housing in the widenedhole, screwed it down, and sealed it with RTV.
Old Oct 16, 2007 | 08:44 AM
USMCrebel's Avatar
USMCrebel
ok once i spend 30min grinding the stuff out, what kind of "super glue/ sealant" would you reccommend?
Old Oct 16, 2007 | 10:20 AM
Starfury's Avatar
Starfury
Well, sealant isn't going to be enough to keep all those aftermarket gauges in place, especially the heavier ones. I just used the RTV to seal the light leaks in the panel. I really wouldn't have any idea what to do with the other gauges until I looked at them.
And you're going to spend a lot more than 30min grinding on the housing
Old Oct 16, 2007 | 10:45 AM
USMCrebel's Avatar
USMCrebel
so after i grind out the panel i will have to make holding brackets to keep them in place....how will those mount up? i know i will spend a fair amount of time on the grinding with the dremel, time is not an issue, how do you do the measurements for the whole or is it just hit and miss guess?
Old Oct 16, 2007 | 11:18 AM
Starfury's Avatar
Starfury
*shrug* I'd have to have everything in front of me. I don't know if the gauges have removable face plates (because you can't leave the glass there), what/where the mounting points are on the housings, how big they are compared to the cluster housing recesses, etc. There's just no way to know unless you have it all layed out in front of you. Then it's just a matter of problem solving and being creative enough to make it all work.
Old Oct 16, 2007 | 11:31 AM
USMCrebel's Avatar
USMCrebel
well, since i have a broken one sitting at home, im gonna go try it out on it, and see if i can get some of the gauges put in.
Old Oct 16, 2007 | 11:40 AM
67Stang68's Avatar
67Stang68
Well, for all you 67 - 68 owners who want to do this swap check out
http://www.edbert.net/gauges.htm
Hope it helps
