Rear disc options
Old Oct 16, 2007 | 07:25 PM
baddog671's Avatar
baddog671
Default Rear disc options
I just bought a new 9" differential housing and I plan to build up a nice unit but within budget. Moser and Currie were too expensive and I can work with some used parts to save dough. I would like to do a disc brake swap to compliment my nice front discs, but alittle unsure what my options are. Got any advice? I was considering Explorer, but don't they use big bearing flanges which wouldnt work on my small bearing unit? So, other than the original 9" discsMustangshad, what should I be looking into.
Thanks ~Nic
Old Oct 16, 2007 | 08:48 PM
Hawkins 812's Avatar
Hawkins 812
Default RE: Rear disc options
You plan on racing it ? Just curious because as a DD, its really just a waste of money.
.....IMO of course. [sm=hail.gif]
-Hawkins
Old Oct 16, 2007 | 09:07 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Take a look at www.mpbrakes.com. They have some budget minded kits that are quality sets.
Old Oct 16, 2007 | 09:41 PM
JamesW's Avatar
JamesW
Check out www.ultrastang.com
Steve there has some good info and a nice choice of setups. I'm running his older Lincoln Mark VII style rear discs.
Old Oct 16, 2007 | 09:55 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the bubble crown vic parts bolt on with a small shim on a small bearing 8 and 9 inch rear i think the shim is something like .130 in thickness to keep the axels from having in and out play after the conversion my ssbc kit had a shim im sure its the same style shim that you would need figure you could get a whole rear for what 40-50$ note the police rears have vented rotors the regular passengers cars are solid
Old Oct 16, 2007 | 11:07 PM
baddog671's Avatar
baddog671
ORIGINAL: Hawkins 812
-Hawkins
Well, no, but its either buy a new set of drums or buy a new set of discs. Might as well lay down the little extra dough for discs. Go big!
James, I've seen that site before. Man he's making a killing on those pieces of steel, hmm?
I'll look into the Vic's Stephen
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
maestro1024
Sep 21, 2015 02:40 PM
Roush05
Sep 10, 2015 12:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
