67 289 distributor.........
Old Feb 24, 2005 | 12:32 AM
ochobolla's Avatar
ochobolla
Default 67 289 distributor.........
does the correct distributor for my 2v 289 have 1 or 2 vacuum ports ??
it currently has 2. what is the 2nd port for ??
thx
Old Feb 24, 2005 | 11:11 AM
6mustang6's Avatar
6mustang6
Default RE: 67 289 distributor.........
No, the correct distributor should only have one. My 66 289 has the original and it's only one.
Old Feb 28, 2005 | 04:41 PM
69mach1377's Avatar
69mach1377
Convert to electronic ignition while your at it...
Old Feb 28, 2005 | 10:21 PM
ochobolla's Avatar
ochobolla
does anyone know what the 2nd vacuum port on the distributor is for ?
Old Feb 28, 2005 | 11:48 PM
Wessy's Avatar
Wessy
Direct quote from Haynes Manual:
The outer (primary) diaphragm senses carburator vacuum just upstream of the throttle butterflies to advance ignition timing; the inner (secondary) diaphragm senses manifold vacuum. Therefore, when the manifold vacuum is high(eg during deceleration or idling) the secondary diaphragm retards the spark. As soon as the throttle is opened, the primary diaphragm takes control and causes the spark to advance. The purpose of this system is to decrease the emission of unburnt hydrocarbons at low throttle openings.
Hope that helps ya!
Old Feb 28, 2005 | 11:53 PM
Wessy's Avatar
Wessy
and if I was you I would go to electronic ignition as 69mach suggested. I've done it and it only ran me about $300.
Old Mar 1, 2005 | 03:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
I went to the Pertronix a few years back, and I will never put the points back in.
Old Mar 1, 2005 | 08:50 PM
ochobolla's Avatar
ochobolla
i appreciate the replies. will definately look into the pertronix.
i hate messin with points.
uberstang1
Dec 7, 2017 07:10 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
ding56
Aug 14, 2015 02:40 AM
