Leaf Springs!?
Old Oct 17, 2007 | 03:19 PM
drewsky's Avatar
drewsky
Default Leaf Springs!?
Planning on getting the Grab A Track handling kit for my 67, and wondering if anyone knows what size/how many leafs you have in the back. There are options from 4 leaf standard eye, to 4 1/2 and 5. all with reverse eye mid eye or standard. Dont tottally know which will make a difference. can anyone help and or know what they have and what looks and rides the best. thanks
Old Oct 17, 2007 | 04:01 PM
boogerschnot's Avatar
boogerschnot
Default RE: Leaf Springs!?
4 should be good for a 67 ,,, 4.5 would be stiffer.. The mid eye would lower your ride,, or depending on how loose your springs are right now, it might actually sit at the same height.. If you plan hauling things, or family around in the back of the car, then I would go 4.5.. reverse eye would drop the rear pretty low.. and standard would actually raise the rear end from where it is now,, at least for a while until the springs start to give a little and settle..
I plan on getting 4.5 mid eye for my rear, just because I plan on dropping it all the way around about an inch in the future.. And I have two kids to put in the back and a drum set on occasion..
Old Oct 17, 2007 | 05:02 PM
67mustang302's Avatar
67mustang302
4.5 is more performance oriented or like was said, if you plan on regularly putting things in it. 5 is prolly gonna be too stiff for the street for most people. 4 would be mild performance but with a bit softer ride than 4.5. It really depends on what you want from the car. And keep in mind that lowering a car means you scrape more. Check your ride height now and compare it with what stock should be, if you're already sitting about 1" lower than stock and you're ok with it, then you might as well get the 1" drop stuff(mid eye). Most of our cars with worn suspension are raised back up to stock height with new springs
Old Oct 17, 2007 | 05:27 PM
Starfury's Avatar
Starfury
I drive with 4-1/2 leafs and I like it. Granted, they're a little old and probably not as stiff as new, but I don't think they're by any means too stiff for street use. Definitely not going to be a cushy ride, but that's what you get when you want better handling
That said, I'd recommend against the Grab-A-Trak stuff, simply because they don't offer it with anything but poly bushings. Poly squeaks, always. Rubber bushings were OE, and midolyne or polygraphite will provide the improved stiffness that standard poly does, without the squeaking.
Old Oct 17, 2007 | 07:25 PM
bluovalguy's Avatar
bluovalguy
I put the 4's on mine not to long ago. My old leafs were attatched to a 4" drop shackle in the back. The new leafs are attached to the regular shackle and the height is about the same for both set ups. So you will see a signifigant difference in your setup. I will pm you before and after pics of mine.
EDIT: I bought the standard eye, 4 leafs
Old Oct 17, 2007 | 07:36 PM
bluovalguy's Avatar
bluovalguy
It wouldnt deliver the email, so I just copied the message:
Before- I had the old 4 leaf with a 4" drop shackle. You can see it sticking out below the quarter panel.
http://s14.photobucket.com/albums/a324/bluovalguy/?action=view¤t=66Mustang3.jpg
After- This is the stance now with the standard eye 4 leaf and the regular shackle.
http://s14.photobucket.com/albums/a324/bluovalguy/?action=view¤t=my66001.jpg
Old Oct 18, 2007 | 01:25 AM
drewsky's Avatar
drewsky
thanks bluovalguy for the pics. thats about how i want my car to sit in back. do you know if thats is stock height or a little higher?
Old Oct 18, 2007 | 07:36 AM
bluovalguy's Avatar
bluovalguy
I BELIEVE (could be wrong) that the original height was 26 1/5 inches from ground tohighest pointof wheel opening. Right now I have 215 70r14's in back, and the when measured from the ground up it is sitting at 28". From the center of rear axle up, it is at 16".
Old Oct 18, 2007 | 02:44 PM
mat11089's Avatar
mat11089
I put 4.5 mideyes with 225 45 r17's and it sits perfect.Ride is stiff and wants to walk a lil if your corner adn theres a few bumps but amazing on flat.Nearly no body roll(obviously thats with other suspension mods too)
Old Oct 18, 2007 | 06:24 PM
baddog671's Avatar
baddog671
I put mid-eye 5 leaf on my 67coupe. I like the way it lowered it, it hugs the tires nicely now. I wouldnt go reverse eye personal, I think that would cause some issues.
Can't say about the handling though, doesn't run. I've heard 5leaf may be harsh..
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
