s/c or TT
Old Oct 21, 2007 | 07:50 PM
blee69mustang's Avatar
blee69mustang
Default s/c or TT
i have a '69 fastback and i want to s/c or turbo it. any one know where i can get a turbo kit, or supercharger kit, for my stang.
thanks
Old Oct 21, 2007 | 08:40 PM
Hawkins 812's Avatar
Hawkins 812
Default RE: s/c or TT
Try a searching google or this forum....or pm cprstreetmachines.
Old Oct 21, 2007 | 10:05 PM
JamesW's Avatar
JamesW
Check out our suppliers down the right hand side....there's a couple
Old Oct 21, 2007 | 10:53 PM
andrewmp6's Avatar
andrewmp6
depends on do you want a roots or centrifugal blower
Old Oct 21, 2007 | 11:11 PM
67mustang302's Avatar
67mustang302
Roots [:'(]Just build a single turbo setup, you'll have more power than you know what to do with
Old Oct 22, 2007 | 08:18 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
roots is a nice old style look, but for effiency you will def want a turbo.
Old Oct 22, 2007 | 08:40 AM
Starfury's Avatar
Starfury
Boo for turbo lag:P
Old Oct 22, 2007 | 08:58 AM
USMCrebel's Avatar
USMCrebel
turbo lag???? for a tt setup you dont put two the same size.....you want a small like 53mm for the quick spool and power, and then the larger one will kick in not to long after.
Old Oct 22, 2007 | 09:10 AM
cprstreetmachines's Avatar
cprstreetmachines
? ...53's are way too small...
turbo lag on a V8 just means you'll start to move forward a little before the tires go up in smoke. on the street any thing over 1/2 throttle is useless till you get above 60mph with an AOD and 3.50 gears.
the only time I feel the lag is when i'm at the track with slicks on. I take off about 2500rpms and smash the foot pedal and the slicks hold- between 2500 and 3500 it takes of like normal (on motor) then about 3500 it feels like the car takes off again like a jet plane (sounds like one too) and never stops
where are you located, all i need to do is take you on a ride and you'll make up your mind.[8D]
PM me with questions
Old Oct 22, 2007 | 09:18 AM
USMCrebel's Avatar
USMCrebel
REALLY? i thought it would be the same, thats a setup a guy with a 4 banger round here has, but i guess i shoulda thought about it first 4 cyl 53 mm half the motr =half the turbo.
