Starting problem?
Old Oct 22, 2007 | 11:53 AM
syfhler's Avatar
syfhler
Default Starting problem?
I have a 65 289 A Code with stock iginition with a pertronoix.
Battery holds 12.2 volts when sitting 12.6 volts just after I shut down. Battery is 14 volts with no load and 13.8V with a full load at idle. Alternator checks good.
I had a spark on my Coil at the positive side but that was due to a bad connection which has been fixed.
When I go to start the carit usuallystarts quickly as it should. Other times the cars starts like it has a weak battery that starter chucks turning over about 1 every 2-3 seconds. If I try to run the starter 6 times or soI willdrainthe battery to the point I will need a jump. Once I drive for a while the battery is back to 12.2 volts after shut down.
My questions is this.
Can a bad starter draw extra amps from battery and drain it quicker than a good starter. Could I just have a bad battery, although it keeps passing battery test with my own battery tester and the ones at autoparts store?
Old Oct 22, 2007 | 11:56 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Starting problem?
could be both, you could have a starter, altenator, that is draining your battery, you could have a ****ty battery that just blows.
Old Oct 22, 2007 | 12:18 PM
syfhler's Avatar
syfhler
I have checked the ALT and the BATTERY and both "CHECK GOOD". I can say that with the Radio, driving lights, fog lights, Heater, and interior lights (Full Loadf) my Batt volt is 13.8~14.0 Volts. So I know that the alt is good. There is no audible slipping noise on the belts and I replaced the Started Sol a few months ago.
Old Oct 22, 2007 | 01:07 PM
Hawkins 812's Avatar
Hawkins 812
I dont understand what your problem is. When you start you car, it sounds like the battery is dead?
Old Oct 22, 2007 | 01:10 PM
erikfall's Avatar
erikfall
did you replace ur voltage regulator?
Old Oct 22, 2007 | 01:12 PM
erikfall's Avatar
erikfall
check for any faulty ground wire
Old Oct 22, 2007 | 01:15 PM
Hawkins 812
Just get a battery with higher cold cranking amps. Problem solved.
Old Oct 22, 2007 | 01:16 PM
syfhler's Avatar
syfhler
ORIGINAL: Hawkins 812
The starter chugs very slowly, as in the battery can barely turn the Starter. If I have the console lights on they will go very dim and the car may or may not start. I know the battery is being drained severly however it keeps checking good.
Old Oct 22, 2007 | 01:17 PM
boogerschnot's Avatar
boogerschnot
It could be the starter like you said earlier..
Old Oct 22, 2007 | 01:22 PM
Hawkins 812
ORIGINAL: boogerschnot
.......or your solenoid.
