Subframe connectors
Old Oct 22, 2007 | 10:46 PM
jcomp's Avatar
jcomp
Default RE: Subframe connectors
I also installed the Tin Man connectors. They fit perfectly and were a good price. Pretty stout, as well.
Old Oct 22, 2007 | 10:47 PM
Hawkins 812's Avatar
Hawkins 812
ORIGINAL: connor90
ORIGINAL: Hawkins 812
I bolted mine when i installed them and later had them welded in. I dont know much about different varietys...i order mine from summit installed them in an hour. Hope this helps. The subframe connectors in general made a huge difference.
Hawkins
did you notice much difference in performance after you welded them? im considering putting some in but am curious if welding them actually makes that much of a difference.
Not that i could tell. I know that there will be constant stress on the frames and welded them for piece of mind and to prevent any problems down the road. The subframe connectors in general made a HUGE difference...one of the best mods ive purchased .
Hope this helps.
-Hawkins
Old Oct 22, 2007 | 10:48 PM
connor90's Avatar
connor90
yeah, it does. thanks.
summit is about a 15 min drive from my house so i might have to check it out.
Old Oct 22, 2007 | 11:21 PM
bb427stang's Avatar
bb427stang
My biggest problem is torque... the body twists when I launch. Did you notice if the Tinman kit reduced the twist on acceleration?
Old Oct 23, 2007 | 12:48 AM
350kmileFord's Avatar
350kmileFord
I bought all the metal (2" square tubing, 1/8"? plating, 2" angle iron pieces) for about $26. Made/installed them myself. Come on guys, learn to weld >_<
Old Oct 23, 2007 | 01:35 AM
andrewmp6's Avatar
andrewmp6
Daze has a how to make them on his site theres alot of different ones out there the weld in ones are better then the bolt in.Also double check your frame rail messurements before welding them in.
Old Oct 23, 2007 | 11:52 AM
bb427stang's Avatar
bb427stang
For the price, I may just have to try Tinman connectors.
Old Oct 23, 2007 | 12:22 PM
DriWashSolutions's Avatar
DriWashSolutions
ORIGINAL: jcomp
+1
I was one of the original "group buy" customers of the Tin Man kit - very solid, perfect fit.
I would suggest that if you still have flex after welding these in, then you'll need to connect them with a either a 4pt or 6pt cage.
Old Oct 23, 2007 | 05:11 PM
ponyX65's Avatar
ponyX65
who's tin man???
Old Oct 24, 2007 | 10:46 PM
valley firearms's Avatar
valley firearms
I ordered my Tin Man's yesterday. Spoke to a nice lady named Amy. She took my order and in 5 minutes we were done. She later called back and said that she can ship USPS as opposed to UPS. She saved me over $25 in shipping versus shipping them UPS.
[align=left] [/align]
