I have 2 questions:
1. May car is a 66 andhas a late model 87-93 5.0 Ford Racing Crate motor. It's carburated and hasthe V-Belts.I mentioned before it is missing the Timing Pointer, so which one of these would I get?
26023B 01
TIMING COVER POINTER 64/73 289/302/351W
$ 7.95
C8AZ6023B 01
TIMING COVER POINTER 68/69 289/302/351W
$ 9.95
UP182 01
BILLET TIMING POINTER CLEAR 79/95 5.0L & 5.8L FORD
$ 50.95
2. How do I / what's involved with replaceing the Transmission Vacuum Modulator on a C4 Automatic
25900A C4, C6 transmission vacuum modulator 1964-72
C4, C6 White stripe (screw in type) vacuum modulator 1964-72
Thanks,
Joe
26023B 01
$ 7.95
C8AZ6023B 01
$ 9.95
UP182 01
$ 50.95
Thanks,
Joe
I am assuming that since you have a Ford Racing crate motor, you are still using the balancer that came with it, correct? If so, the timing indicator bolts to the passenger side of the balancer. You can use the third pointer listed (billet), but I'd just go to your Ford dealer or a pick-a-part and get one off of a 5.0L engine.
Im currently ordering the same VModulator as well. Its a good idea to use a steel hose from the carby to the modulator so the exhaust doesnt cause it to rip/tear down the road. Use about 3 in. of rubber hose at each end and you will be good to go.
The timing pointer depends on what you have. The first and second ones are the same. They bolt to the cover(which both require a pre-existing hole to mount to) on the driverside. You could run that one if you could get it on there, IF, you don't have a driverside exit. If it's stock, you won't have that.
It looks like I will have to go with one that is for a 5.0 (87-93) which mounts on the passenger side,because I have a staggered outlet radiator and the lower radiator hose is on the driver side.
And it looks like the tranny modulator should not be a big deal. My understanding it comes pre set from Ford. I can adjust it if neccessary.
Thanks Again.
Thanks Again.
jaystang
Feb 5, 2006 06:22 PM
