bum spring or no?
Old Oct 23, 2007 | 04:31 PM
66ckurt's Avatar
66ckurt
Default bum spring or no?
right now im trying to figure out why my car has a 1/2 inch difference in ride hight on the front. i have it all apart and ive noticed a couple things; 1 is that i had both springs not completely seated right, theres a little lip that the bottom of the spring sits up against and each side was not fully touching this lip/stop the higher side was off by like 3/8 and the other was 1/4. 2 the springs are not exactly the same size ones 1/8 taller. lastly is in the attached picture the taller springs flattened side is thicker. I can easily fix the first problem but the spring problems im not quite sure what to do. Any feed back would be very helpful
kurtis
[IMG]local://upfiles/25167/EB5B8EB8AF944069A03BF971AF119DF2.jpg[/IMG]
Old Oct 23, 2007 | 05:54 PM
baddog671's Avatar
baddog671
Default RE: bum spring or no?
Where did you purchase the springs from?
They should be up against that little lip on the saddle, but that shouldnt make much of a difference. Perhaps they sent you 2 different rated springs and the one is just more compressed than the other.
I'd put the 1/8" one on the driver's side to compensate driver weight.
Old Oct 26, 2007 | 05:08 PM
66ckurt's Avatar
66ckurt
i got the springs from canadian mustang and there usually spot on except for these and the carlo bar i bought but from the look of that most of them tend not to fit. i might drop into canadian mustangs and see what they say about the springs before i got ahead and put them back in i got another problem in the front end so im in no rush to get it back on the road.
CS2007
Jun 25, 2019 09:45 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
mungodrums
Sep 28, 2015 10:54 PM
