torque converter
Old Oct 24, 2007 | 09:50 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default torque converter
I need to know if I need to replace my torque converter, and if so, which one do I get (and where)? I just want a stock one, nothin crazy.
It's an 200 I6 with a stock C4. I'm rebuilding the C4, and don't know if I need to re-use or get another. Let me know if more info is needed, cause I'm clueless.
Old Oct 24, 2007 | 09:54 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: torque converter
http://www.parts123.com/parts123/yb.dll?parta~partsort
Old Oct 24, 2007 | 09:56 AM
USMCrebel's Avatar
USMCrebel
i think i have an extra one laying around, ill call down to my "shop" when i get home and find out for you.
Old Oct 24, 2007 | 09:58 AM
TexasAxMan's Avatar
TexasAxMan
Always use a new torque converter with a transmission rebuild.
Old Oct 24, 2007 | 10:22 AM
mySAVIOReigns
good, I'm glad I knew that and didn't use the old one.
Sorry USMC, the link was dead. But I did search O'Reilly's website and they had one. Why I thought a general parts store wouldn't have one, I have no idea.
The have three to choose from (it must be a 24 spline input shaft):
2300-2500 RPM (seems to be most stock-ish)
Comp Cams 274 (2:1 torque mult.)
Comp Cams 284 (2.2:1 torque mult.)
none have prices, but I couldn't imagine more than $200.
So which one should i get? Any ideas?
Old Oct 24, 2007 | 11:56 AM
mySAVIOReigns
Well I called them, and none of them have the ring gear installed already. Now what do I do...
Old Oct 24, 2007 | 02:17 PM
TexasAxMan's Avatar
TexasAxMan
What ring gear are you talking about?
Old Oct 24, 2007 | 02:20 PM
Hawkins 812's Avatar
Hawkins 812
Im not 100% sure ... but i believe the stock TC is around 16-1800 stall if your going for stock.
Old Oct 24, 2007 | 02:22 PM
jlg2002's Avatar
jlg2002
Savior, none of the torque converters have ring gears, its part of the flexplate. Get the cheapest rebuilt TQ you can find for your I6. should be less than 120 bucks
Old Oct 24, 2007 | 02:43 PM
mySAVIOReigns
since it's a 200ci, the ring (starter) gear is welded onto the TC.
After like 67 or something, they put it on the flexplate.
