springs
Old Oct 29, 2007 | 07:40 PM
dr1965's Avatar
dr1965
Default springs
i know there has been a thousand threads on replacement of rear leaf springs, but i went under the search and none came up. Could someone please do a reply, or a post where someone has replaced rear springs and how they did it. I am ordering new springs tonight, and i have a general idea of how to do so. Just looking for someone that has done it, and there views on it,promblems and pointers.thanks.
Old Oct 29, 2007 | 08:05 PM
Matt.69Stang's Avatar
Matt.69Stang
Default RE: springs
One of your best bets is to go on amazon and order the Chilton manual for the mustang. It shows a good section on the rear suspension.
Old Oct 29, 2007 | 08:33 PM
ebluekeys's Avatar
ebluekeys
Default RE: springs
I made the mistake of ordering the "heavy duty" springs, figuring it would "tighten up" the ride. All it did was make the rear end hop around when it hits bumps while accelerating. Buy the STOCK SPRINGS!!
Old Oct 29, 2007 | 10:08 PM
baddog671's Avatar
baddog671
Default RE: springs
Go ahead and buy yourself either a sawzaw or a 6.5" cutoff wheel, perferrably the sawzaw. Unless your suspension has been messed with before, you will HAVE to cut the front bolt to drop the leaf springs out.
Other than that, its a simple job..
JMD's Avatar
JMD
Default RE: springs
ORIGINAL: ebluekeys
IDK,,,
We put 5 leaf grab-a-tracks on the 66,,, no hops at all,,, just hooks and goes...
As far as changing the springs it is pretty straight forward....
Put the frame on jackstands,,, high and securely...
Drop the driveshaft
Remove the e-brake cables, Probably will be easier to drop the cables from the car and not the axle.
Remove brake line from bottom of car to axle
Remove spring shackles from rear of springs and car. (with jack lightly under the pumpkin)
Remove jack from pumpkin, axle will "hinge down" from front of springs
Remove the two U-bolts from each side, axle will be free now, leave it where it is.
Remove the front spring bolts..... if they are stuck, then you will need a new thread,[:@][:@]
Springs are now free.
Reverse procedure in assembley...
If the front bolts are not stuck, this is about a 2 hour job... if they are stuck you will need a sawsall,and/or other assorted cutting tools, a lot of patience, and a good 4 letter vocabulary... (ours came right out no issue)
Old Oct 29, 2007 | 10:15 PM
Starfury's Avatar
Starfury
Default RE: springs
Wheel hop is normal on these cars. A set of traction masters would fix that problem.
Old Oct 29, 2007 | 10:29 PM
JamesW's Avatar
JamesW
Default RE: springs
When I changed mine, I didn't have to cut the bolts holding the front spring mounts. I soaked them in penetrating fluid the day before and they came loose.
Depending on the ride height you're trying to achieve, there are standard, mid and reverse eye springs. I went with standard height.
Be careful in how you secure the car. You will need at least 4 jackstands. 2 under the axle and 2 under the rear framerails next to the springs. In the photo below for reference, I placed one set of jackstands on the rear frame rail just about where that hole in the framerail is located.
You want to support the car by the aft framerails. letting the rear end hang under it's own weight. (minus wheels) Unbolt the spring perches and release the axle from the spring. Jack up the axle so it raises off the spring. Then remove and replace the spring. One side at a time.
Old Oct 30, 2007 | 07:56 AM
dr1965's Avatar
dr1965
Default RE: springs
2 things-Do you have to drop the driveshaft?
-and do you have to disconnect the brake hose?
seems easy enough.I am not sure if the rear endwas ever apart before, so i am planning on the worse.
Old Oct 30, 2007 | 08:48 AM
mortman's Avatar
mortman
Default RE: springs
I did not have to drop the breakline or disconect the E-Brake cable, my front bolts came out easily but the rear shackels sure caused a bloody mess of my nuckels
Old Oct 30, 2007 | 10:03 AM
JMD's Avatar
JMD
Default RE: springs
ORIGINAL: dr1965
Yea I thought about that after posting, I was going to make a correction but my post disappeared into the ether due to a posting error...
all that really needs to come off is the springs, the wheels and tires can/should be left on, unless the front bolts are a bitch, in that case a person might want the axle out of the way for an extended unobstructed session with the bolts.....
