Our backwards resto....66 vert!
Old Apr 29, 2008 | 09:44 PM
  #171
tarafied1's Avatar
tarafied1
Default RE: Our backwards resto....66 vert!
ORIGINAL: BA Mustang
No his is the E kit. The E2 kit is made for 65-66.
E kit 67-68
E2 65-66
Yes, My kit is the E kit for 67-68 Mustangs, the E2 kit is for the 1st generation Stangs. I have the Maier racing kit except for the trunk lid and tail light panel. I have the Shelby/California Special trunk lid and Shelby tail light panel. I filled in the notches in the upper and lower nose for the driving lights because I used a 67 Shelby grille.
Old Apr 30, 2008 | 12:38 AM
  #172
RGMotorsports's Avatar
RGMotorsports
dang 367hp, I wouldve thought maybe for a performer rpm top kit for 351w, but for a 289/302 thats real good.
Old Apr 30, 2008 | 02:47 AM
  #173
Toddman0025's Avatar
Toddman0025
I love this thread thanks for keeping us updated on your progress!
I have a question for you regarding your application of POR15 (i'm getting ready to do the same thing):
I was under the impression that you just used phosphoric acid and then applied the POR15 directly over the painted areas - do you actually need to strip all the paint off before applying POR15?
Old Apr 30, 2008 | 05:44 AM
  #174
jamieNerikas66stang's Avatar
jamieNerikas66stang
DO NOT PUT POR15 OVER PAINT, it will not stick and it will just peel off,...POR stands for paint over rust,...YOU MUST use their three step process,..
1. degreaser
2. metal prep
3. por 15
if using on bare metal, scuff it up a bit with some sand paper,...and then spray degreaser and let sit for about 10 minutes, wash clean with clean water, spray metal prep and let sit for about 15-20 minutes and wash clean again, dry, then you are ready for the po15,...if you dont do these steps, you will not have good results and it will begind to peel on you
Old May 6, 2008 | 08:07 PM
  #175
jamieNerikas66stang
gears came yesterday and dropped the rear off for a complete rebuild,...MMMMMM
should be done friday-ish
fenders also came in,..time to start cracking away at some of the metal and body work now,..summer is here
Old May 7, 2008 | 10:49 AM
  #176
03Maverik's Avatar
03Maverik
Hurry...Hurry...Hurry!!!
Actually take your time. It's been perfect so far. No need in rushing to finish and screw something up!!!
Old May 7, 2008 | 10:28 PM
  #177
pjlietz's Avatar
pjlietz
Wow man, great work! I just read through the whole log and can't wait to see more! I'll be using this thread as insperation to get moving faster on rebuilding my '66.
Old May 7, 2008 | 11:17 PM
  #178
Hot70Mach1's Avatar
Hot70Mach1
its 12:08. i have school tomorrow at 6 in the morning. and ive driven over 400 miles today.
i just started reading this thread. and i started on page one. and read all nine because i couldnt tear myself away. every single post. all 176.
im furious. im straight up mad. this is ridicioulus.
why havent i been following this from the begining[:@]!!!!!!!!
youve done one of the best restos ive seen in a long time. dont lose your momentum.
and nice STI probably fav sti second only to the mustang.
hope my next project turns out this ultimate.
Old May 9, 2008 | 05:02 PM
  #179
jamieNerikas66stang
rear shackles, u bolts, 5 leaf reverse eye springs, kyb gas a ajust shocks, 1/2 lowering blocks, and shock plates,..not shown,..just waiting on the rear to get back from rebuild cause i want to put it in as a whole ,...
i am worried about how low it is going to sit since i have made up my mind on wheels,...18x8 in the rear and 17x8 up front,...i should have the whole tire tucked in the rear maybe more if i planned it right...hopefully!
Old May 10, 2008 | 05:01 PM
  #180
straw1628's Avatar
straw1628
Jamie, just curious. It looks like you have an air gap intake on the car. That is what I am using. Do you think you will have any hood clearance issues? Thanks.
