Our backwards resto....66 vert!
my goal is to be able to drive the car most of the summer, get all the bugs worked out, mess around with it a bit over winter, and then have it painted the following summer,...i dont want to be leaning over a fresh paint job working on things,...it should be at paint this coming week to have the bay sprayed,...then i can get new engine in and trans,...
i tried the spring without a compressor and there is just no way,..
Someone makes shock tower support plates that go from the area of the frame rail that gets all the dirt built up to the shock tower just below the UCA mounting point. This does two things. It strengthens that area of the shock tower, and it deflects the dirt (due to the ~40* angle). Can't remember who makes them. We used to just make them ourselves, by cutting out a cardboard template, transfering to a piece of 1/8" plate and welding it up.
Great progress! All that shiny metal
not much of a update, but been doing alot of busy work,..like going through the wiring harness and stuff like that, lights, etc..cleaning alot of old parts and geting things ready to send out for rebuilds,...but here are some pics,..
had to cut the old shifter setup out, it was so rusted, it kind of rusted itself together and the bolts are snapped as soon as i put on pressure on them,..so had to cut old one out, install new shifter, and new shifer bezel,..the can will eventually be converted to manual, but stays auto for now...
also decided to replace the entire radiator support and crossmember,...it didnt need to be replaced, but there where holes drilled in it, it was bent, and out of wack, and i knew if i sent it to paint like this, i would never be happy,..so out it came,...pretty cool to see the grease markings from the assembly line on the car and what it was going to be,...i will be saving this piece just for ****s and giggles
new rad support with crossmember already welded in,..wow this was a huge advantage and big time saver, well worth the extra money
you can see metal support to hold the car inplace so nothing moves,..
drilling out spot welds,..what a pain
new test fit, could not have asked for a better repo piece, it was a heavier metal then the stock oem one, and the fit was beyond perfect
removed new piece drilled a bunch of holes,...for the welds
the tweeter himself welding up some holes.hhahaha
done!,..and worth every minute, now i am happy
Congrats on the deal of a lifetime! Its your ride do what YOU want to do to it!Who cares what someone else thinks!!If you are happy with the final rresults thats all that matters!! Good Luck with it!!
dude, fedex hooked it up today, its amazing how you can have a ****ty day at work and be pissed and miserable,..come home to see a box on your step and all is better
new power steering unit from chockstang,...absolutly awesome peice,...
old one..
new gear box from them too, that should be here later this week,..
old one..
