Heater Control Plate
Old Nov 5, 2007 | 08:28 PM
zuluracerx's Avatar
zuluracerx
Default Heater Control Plate
Can anyone tell me how to remove the heater control panel on my 66 fastback? Specifically, the chrome controls on the lower dash. I know it sounds ridiculously simple, but I can;t figure out how it is secured to the dash, there is very little working area to see how it is built and I do not want to force it. Thanks to anyone who can help me out!
Old Nov 5, 2007 | 08:50 PM
mustanglover66's Avatar
mustanglover66
Default RE: Heater Control Plate
I just finished taking all that stuff out of my car a while ago, if memory serves me there are 2 or 3 nuts on the backside I think 1 on the top and 2 at the bottom they are a pain to reach and almost imposible to see and that was one of the last things I removed.
Old Nov 5, 2007 | 09:04 PM
DriWashSolutions's Avatar
DriWashSolutions
Crawl under the dash (from the passenger side), and you should see the three cables attached to controls. Remove them first and get them out of the way - then it should become clear how to get the panel out of the dash.
Old Nov 6, 2007 | 04:43 AM
smittycm's Avatar
smittycm
Actually, you don't have to undo the cables first. It just depends on what you want to do. If you just want to replace a pitted faceplate, then you don't have to undo the cables. There are two studs w/ either 1/4" or 3/8" nuts on the back of the plate that hold it onto the dash. They are caddy corner to each other and really are a pain in the rear to get to. They are just in an awkward spot to get to with a wrench. After getting them off though, the whole assembly will come out up until you reach the end of the slack in the cables. If you just want to replace the plate, you can unbolt it from the rest of the assembly after using an allen key (2mm?) to remove the separate ***** on the ends of the levers.
Old Nov 6, 2007 | 06:37 AM
67 evil eleanor's Avatar
67 evil eleanor
Ford used 8 year olds when they installed these (two per side). They had someone hold them by the ankles and insert their head and shoulders under the dash, and they would make the installation. I know what you are talking about, as 6'2" and 240lbs I don't fit too well under their any more. Even when woller in the position, I can hardly bend my arms and hands to work. I think their is a couple nuts on the back that holds the assembly. They are hard to get to and sometimes even harder to remove. good luck.
Old Nov 6, 2007 | 07:03 AM
sixtysix's Avatar
sixtysix
Thats funny-I have a 8 year old boy and I used his little hands to get my oil pressure send unit started in the threads so I could get a wrench on it...It really helped me out and it boosted his sself confidence ! What a good father I am!
Old Nov 6, 2007 | 08:51 AM
zuluracerx's Avatar
zuluracerx
ORIGINAL: sixtysix
Think I could borrow him to help me with this task...lol
Thanks to everyone for the info!
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
