Speed question
Old Nov 7, 2007 | 04:52 PM
Reverb's Avatar
Reverb
Default Speed question
This might be a bit of a newbie question,
when you change the rear end ratio, does it effect the speed reading and how do you rectify it if it does?
Old Nov 7, 2007 | 04:57 PM
dodgestang's Avatar
dodgestang
Default RE: Speed question
ORIGINAL: Reverb
Yes it does, you will need to change the speedo gear that is plugged into the transmission and attached to the speedo cable. Take the old one....count the teeth multiple it (or divid depending on they type of gear change up.down) by the percentage difference between your old gears and your new gears. Then order a new speedo gear with that number of teeth.
Old Nov 7, 2007 | 07:30 PM
Reverb's Avatar
Reverb
Thanks for that
mtgldr
Feb 3, 2024 09:00 PM
musnicki
Sep 23, 2015 07:11 AM
Mustangmalo
Sep 6, 2015 05:22 PM
