Tranny issues....
Old Nov 12, 2007 | 10:45 PM
mat11089's Avatar
mat11089
Default Tranny issues....
I have a 66 with 302 and c4.I the c4 checked witha very reliable tranny shop back in april.I was told it had a rebuild no more than a few years old on it.I blew air through the valve body and through tranny to check clutch packs and said they were all good.Everything was fine for awhile now.When in drive or first.nothing.NOt nothing like low fluid where itll go just not til high rpms but nothing at all.REverse works most of the time(dad told me today it wouldnt go in revers for him and thats the only time i know of.) If i slide the shifter back to revers or park and back down with a lil speed it goes in.I havent checked the linkage..could that be it or am i looking at a new tranny?If sowhats my best bang for the buck.if i HAVE to do it i want it to handle a few upgrades im going to do to the 302.
Old Nov 13, 2007 | 07:03 PM
mat11089's Avatar
mat11089
Default RE: Tranny issues....
Any of the long time members out there i know they got ideas on this stuff or newbies..
Old Nov 14, 2007 | 09:57 AM
TexasAxMan's Avatar
TexasAxMan
I don't know a whole lot about auto trannys, but have you checked out the vacuum modulator? I know when they go bad they can cause problems. Otherwise, take it to another tranny shop and have them check it out again.
Old Nov 14, 2007 | 08:39 PM
mat11089's Avatar
mat11089
No offence but i can only get responses from people that DO know about auto trannys.Thanks for the response but this thread is about an auto tranny therefore i need info about AUTO's.Vac Mods only control 2nd to 3rd shift.1st is mechanical.thanks anyways.
Old Nov 14, 2007 | 08:54 PM
mustanglover66's Avatar
mustanglover66
I would check the linkage first that could be your problem if they are not right you may not be fully in gear. And I dout its the same as the trino I had many years ago which was the bands needed adjusting with that car secound gear was the first to go. Its been awhile since I adjusted a auto trans. so I can't tell you the best way to do it but there are others here to better explian it. If no thing else my post will help keep this near the top for everyone to see.
Old Nov 14, 2007 | 08:57 PM
mat11089's Avatar
mat11089
thats what i needed thank you.the bands were adjustedso im thinkin maybe it is the linkage
Old Nov 14, 2007 | 09:25 PM
toolwench's Avatar
toolwench
My original C4 lost 2nd gear. It'd go fine from first to third. I drove it like that for a year. But my problem was different than what you have there. In any case I'd start with the linkage because it's the cheapest. Beyond that, I'd use that problem as an excuse to upgrade the tranny. I've been running a TCI Streetfighter C4 with a 2200-ish converter for 7 years now and haven't had a problem. Good luck.
Old Nov 14, 2007 | 10:14 PM
tarafied1's Avatar
tarafied1
ORIGINAL: mat11089
The neutral safety switch works off of the shift selector lever in the trans. If the linkage is the issue then it might still be in park at the trans when the shifter is in gear. Quick check, try starting it in gear (put on the brake of course). If it starts in gear and still won't move the linkage may be the issue. You could also try to see if it rolls in neutral. If it'sstill in park at the trans it won't roll even if the shifter is in neutral...
Old Nov 14, 2007 | 10:53 PM
mat11089's Avatar
mat11089
awesome thank u guys so much
Old Nov 16, 2007 | 12:16 PM
mat11089's Avatar
mat11089
It was the linkage.It was almost between gears.seems all good now.thanks for the input
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
