What is this called? Description
Old Nov 14, 2007 | 06:04 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: What is this called? Description
is it plastic or steel? id patch it with some glass if it cant be welded esp since its gonna be hidden once the car is assembled
Old Nov 14, 2007 | 06:40 PM
Reverb's Avatar
Reverb
Its steel. i wanted to do a proper job on it, but might have to patch it if i cant find a replacement
Old Nov 14, 2007 | 08:07 PM
dcohen's Avatar
dcohen
if you do a good job patching it then you wont be able to tell anything has been done to it, and if it doesnt look to pretty, who cares? its gonna be hidden anyway
Old Nov 14, 2007 | 08:10 PM
6marc5's Avatar
6marc5
ORIGINAL: Reverb
Its part of the inner fender, fits under the rear section of the outer fender behind the rear section of the apron. In the restoration guide its numbered 02044
1970 Mach1
I searched through 5 sites and had no luck at all finding a patch for it.
Old Nov 14, 2007 | 08:11 PM
dcohen's Avatar
dcohen
make a patch
Old Nov 14, 2007 | 08:13 PM
Reverb's Avatar
Reverb
ORIGINAL: dcohen
make a patch
I might have to. It's not flat which is the problem, i'll have to match the curve - want to use as little filler as possible.
Old Nov 14, 2007 | 08:28 PM
dcohen's Avatar
dcohen
the best way to make a patch is to cut out all the rusted metal (as little as possible, but get rid of the rust)
then take some cardboard paper and form it over the hole, trace it then cut it out and use that as a template for your metal peice
it will take a little effort, but it can be done and shouldnt look to bad, and it will be all covered, so you wont really have to use any filler
Old Nov 15, 2007 | 05:36 AM
andrewmp6's Avatar
andrewmp6
Yes make a metal patch for it fiberglass will come loose over time and youll be stuck doing it again.
Old Nov 15, 2007 | 06:56 AM
109jb's Avatar
109jb
I had to do this on my 70. I am out of town, but will send a fewpics of what I did when I get home. Either late tonight or some time tomorrow.
Old Nov 15, 2007 | 10:44 AM
Reverb's Avatar
Reverb
ORIGINAL: 109jb
Thanks it will be helpful.
