What is this called? Description
Old Nov 15, 2007 | 02:45 PM
  #21
jlg2002's Avatar
jlg2002
Default RE: What is this called? Description
Go to cj pony parts and look at part no M350L or R I think this is what you're looking for.
http://www.cjponyparts.com/
Old Nov 15, 2007 | 03:17 PM
  #22
chillininnh's Avatar
chillininnh
I agree, just make the best patch you can and weld it up, you won't be able to see it when the car is reassembled. The cowl drains in the bottom of that panel, over time the drain gets plugged up with debris, holding in the moisture until it starts to rot.
Old Nov 15, 2007 | 06:02 PM
  #23
DanK69RustangVert's Avatar
DanK69RustangVert
You will have to make your patch, nobody sells that par. Cowl = fix it yourself. I have to do the same on the driver's side of mine.
Old Nov 15, 2007 | 06:19 PM
  #24
Reverb's Avatar
Reverb
ORIGINAL: DanK69RustangVert
This is what it looks like. Think you are right, can't find it anywhere - 02044
Old Nov 15, 2007 | 10:44 PM
  #25
109jb's Avatar
109jb
Here are the pictures of how I repaired the lower portion of my side cowl. None of the pieces I fabricated had complex bends, just simple bends over the side of my workbench. I used a total of 3 pieces to make this repair. You just need to make sure the vent assembly still clears. The way mine is it still does.
Hope this helps.
[IMG]local://upfiles/81769/E7672D58532241F588473B978D7385B5.jpg[/IMG]
[IMG]local://upfiles/81769/331F12C06D594296963B3B92A9D2CB05.jpg[/IMG]
[IMG]local://upfiles/81769/7FCB18934A8249158BC609DCFB155639.jpg[/IMG]
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
ChampInSD
Oct 2, 2015 04:55 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
uberstang1
Sep 20, 2015 06:42 PM
