Tranny help
Old Nov 19, 2007 | 11:21 AM
sixt5's Avatar
sixt5
Default Tranny help
in my search to find a T5 and related parts, i found a guy who has a complete setup from an orginal mustang (toploader 4 spd).
he said i could have everything for 1k. would it be worth it getting this setup or going for the t5? i wouldnt have to worry about any incoviences (driveshaft,cables,linkages) with the 4spd, but i wont have overdrive.
what do you think?
Old Nov 19, 2007 | 12:28 PM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: Tranny help
IMO, I would go with the T5, but that's a personal preference...
Old Nov 19, 2007 | 02:35 PM
Kramer's Avatar
Kramer
depends on what you're driving it for. if you don't domuch freeway driving then it would probably be fine. I bought my t-5 for $100 + rebuild kit ($250) and remanufactured output shaft ($85)
Old Nov 19, 2007 | 02:50 PM
gothand's Avatar
gothand
I would still go for the T5. BTW, unless I'm remembering wrong, you'll still need to deal with a different yoke and/or shortening or lengthening the driveshaft when going from C4 to toploader. Also, C4 to T5 uses the same speedo cable and gear.
BTW, if the toploader's shift linkage has not been redone in all these years, it may not be fun shifting it. BTDT.
Good luck whichever way you go.
Jeff
Old Nov 25, 2007 | 01:29 PM
sixt5's Avatar
sixt5
well i got it home, the 4 speed that is. i can not believe how good it looks. brand new hurst shifter and shifter rods (goes fom shaft to the tranny), all new gaskets, VERY clean. he didnt know which bellhousing i had (5 or 6 bolt) so he gave me both. i got all the brackets,rods,linkages, PEDAL ASSEMBLY.
cant wait!!
Old Nov 25, 2007 | 03:34 PM
sixt5's Avatar
sixt5
well i took the tag numbers and ran them through a decoder i found online. RUG-E3 was the code. done a little searchin and a lot of websites came up about this tranny being in a boss 302 car.
http://www.boss302.com/topload.htm
http://www.1969boss302.com/eng_tra.htm
is there anyway can find this out for sure??
Old Nov 25, 2007 | 05:59 PM
sixt5's Avatar
sixt5
false alarm.. oh well. stil gonna have fun outta this sucker!
Old Nov 25, 2007 | 06:35 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I'd of gone t-5........once you go from 4 to 5 speed in a classic..you'll never wanna go back......been there done that......sure is nice having 3.50 gears and cruising at 2000 rpm's instead of 3000 like I used too.......now I need more than 3.50's!!!! I'm thinkin 3.73's or even possibly 3.89's!!!! as I got a lot to play with now
Old Nov 25, 2007 | 06:50 PM
sixt5's Avatar
sixt5
i wont be doing very much highway anyways. be a street car that i just wanna have fun with.
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
