fuel pump ?
Old Nov 20, 2007 | 06:25 PM
eep4life's Avatar
eep4life
Default fuel pump ?
ok so im going to be installing a electric fuel pump... my question is... if it is sending fuel at uniform speed.. all the time wont it flood the carb when ur at idle.....
Old Nov 20, 2007 | 06:34 PM
DriWashSolutions's Avatar
DriWashSolutions
Default RE: fuel pump ?
There's a little device called a needle and seat - it's basically a flow valve which is attached to the float - it regulates the amount of fuel that comes into the bowl/carb.
Old Nov 20, 2007 | 11:06 PM
mat11089's Avatar
mat11089
yeah and its no different than a mechanical they feed fuel all the time too.
Old Nov 21, 2007 | 06:47 AM
falconfixer's Avatar
falconfixer
^ 'As long as it is the same pressure and volume as the mechanical one it replaces'
I would install a pressure regulator/return set at ~5psi above the stock pressure. Consider a 'roll over' crash type protection - do you want this pumping fuel in a crash?
Perhaps a good mechanical pump is better if you are not going EFI....
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
