car surging/jumping
Old Nov 21, 2007 | 04:08 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Default RE: car surging/jumping
Check the timing and make sure the vacuum advance is working.
Old Nov 21, 2007 | 08:05 PM
kaiser18's Avatar
kaiser18
I replaced my carb a few weeks ago and I was having similar issues aswell, it was surging and even stalling in some cases. I replaced the injection nozzle from the new carb with the nozzle from my old carb and problem solved.
Old Nov 21, 2007 | 08:30 PM
kdkeller's Avatar
kdkeller
My first thought was low fuel pressure resulting from a bad pump (diaphram shot, broken trigger arm, etc.) or restriction in the line. If fuel pressure is fine, could you have a motor mount problem? Is the engine literally moving around in the engine bay?
To check: With the hood up, put it in gear, hold the brake and rev the engine. If the engine lifts up too far on the mounts, the mounts are shot.
Old Nov 21, 2007 | 09:19 PM
knuckless's Avatar
knuckless
ok its not a fuel problem in my opinion. the car rev and engine speed isnt alternating at all. theres no other way to explain in other than the whole clutch issue i was saying before. its either timing or transmission problem in my opinion, the engine is getting plenty of fuel, i put a new carb on already,
whenever i floor it out of a stand still its like im holding the clutch half in (its an automatic=no clutch) but whenever im cruising and floor it, it puts up excellently
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
