bored motor
Old Nov 22, 2007 | 04:59 PM
ky's Avatar
ky
America ftw
Default bored motor
so i pulled my 289 out yester day and tore it down. i was almost positive that it was original and had never been pulled out before. until, i start to pull the harmonic off, and someone had broken a bolt off in one of the puller holes. i said "oh crap someones been into this thing before" cause i knew the factory wouldnt have done that, plus, theres no need for the three holes when your installing it! after i got the pistons out, i pulled out the 'ol calipers, and its already been bored to 30 thousandths! im so pissed. for a 289, its not a good idea to go anything over .030 right???? cause itll run hot. can i still use my block if i just hone it? or should i ditch it and use my 302 block? i wanted to use my 289 cause im restoring to original and its a GT so i want the right block.
Old Nov 22, 2007 | 05:21 PM
67mustang302's Avatar
67mustang302
Default RE: bored motor
You should be able to go .040 without trouble, that's what my 302 is at, and I have no cooling problems.
Old Nov 22, 2007 | 05:58 PM
Starfury's Avatar
Starfury
If you're restoring a factory GT, I'd just push it to .040. If it wasn't a GT car, I'd say find another block. But someone down the road may want to buy a GT with a date code correct block
Old Nov 22, 2007 | 06:12 PM
ky's Avatar
ky
America ftw
yeah it deffinately is a GT. 100% sure. so i guess i should keep the block. i work at a engine machine shop so i get all the machine work for free and all the parts at our cost. which is like 25-30% off everything.
Old Nov 22, 2007 | 06:58 PM
67mustang302
Just go .040 over, worst case scenario it might need a larger radiator and/or a better water pump. I'm running a stock style 3 row radiator with a Milodon high volume water pump and have no heating issues, even in the summer. And it gets over 100* around here regularly.
Old Nov 22, 2007 | 08:08 PM
my77stang's Avatar
my77stang
.040 your fine, and hell even if there is a small little brow at the top of the cylinder you'll be fine
Old Nov 22, 2007 | 08:17 PM
dcohen's Avatar
dcohen
i thought the same thing about my 289, come to find out it had been bored .060 over
i guess we will find out if a 289 bored .060 over will get hot, i plan on a bigger aluminum radiator and a highvolume water pump
Old Nov 22, 2007 | 08:18 PM
dirtydave289's Avatar
dirtydave289
Dang i thought .040 over was pushing it
Old Nov 22, 2007 | 09:14 PM
Starfury's Avatar
Starfury
.040 is pushing it. SBF's use thin-wall castings, and core shift isn't uncommon, so boring any more than that tends to narrow the cylinder walls so much that you end up putting too much heat into the cooling system.
Old Nov 22, 2007 | 09:37 PM
ky's Avatar
ky
America ftw
well everyone that has .040 over says its fine on theirs.
