building 351w
Old Nov 24, 2007 | 02:43 PM
project.65's Avatar
project.65
Default building 351w
I am going to send my block to the shop to get it cleaned up and ready for the rebuild. I need some recommondations on good combos. This will be a daily driver, but need some good power just incase the chevys want 2 play
I need :
- intake.
- carb.
- cam.
-heads. ...I will be running stock '69 heads for a month or so but want to buy some good heads.
and for my rebuild kit should I get flat-top or dish pistons? forged or hypereutectic??
- should i buy a summit rebuild kit or does anyone know of any better ones?[/align]
Old Nov 24, 2007 | 03:06 PM
cmanf's Avatar
cmanf
Default RE: building 351w
http://www.edelbrock.com/automotive_...packages.shtml
Looks like a good place to start. The power combos they have already done the homework and know what works best with their own products.
Old Nov 24, 2007 | 09:05 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Give the guys at Comp Cams a call and let them know what you intend to do with the car and they'll give you some good recommendations.
A high-rise dual plane is generally pretty good street option. A single void beneath the carb before the intake divider will help will mid-range response.
You're likely to wind up with a cam in the low 500 lift and high 220 duration (at 050 lift).
For a carb, I'd go with either a Holley or Demon. I prefer double pumpers for their ease of tuning and flexability. I also like single plane intakes, even though they can exhibit some rough edges if not set up correctly or are too tall for the application.
Old Nov 24, 2007 | 10:30 PM
03BottleFedGT's Avatar
03BottleFedGT
i would use forged pistone over hypers. the performer intake. holley double pump 650-750 cfm carb. and have a cam custom ground for the car normally does'nt caost much more than buying an over the counter.
Old Nov 24, 2007 | 10:46 PM
67mustang302's Avatar
67mustang302
Use good forged pistons and at least good ARP bolts in everything, that way if you want to put nitrous on it later you can, or a bit of boost. Plus, forged pistons are a lot lighter. If not, hypers work well for a lower cost alternative. For heads, if I were doing a 351W I'd look into using Edelbrocks new Pro Port CNC'd RPM heads(you'd have to call them about it though, since they're basically not listed anywhere assembled). Intake/carb/cam combo is also gonna be affected by gearing and what you want out of the car. A Performer RPM would work nicely, and a roller cam if you can afford it.
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
the5
Sep 19, 2015 06:13 PM
