Boss 351 Rotating Assembly
Old Nov 28, 2007 | 09:52 PM
mustang289's Avatar
mustang289
Default Boss 351 Rotating Assembly
Well, its time for more power, the 69 heads, while they do flow pretty well for a SBF head, are just not cutting it. I've been looking and looking and I would like something around a 60cc chamber, and some nice size vavles. I have a 351W sitting at my house and would like to ask a few questions concerning the placement of Boss heads atop the block. Please keep in mind, I am in the very early stages and I am just trying to figure out my options. I know I probably won't have any power in the low end due to the port size however, please let me know any strengths and weaknesses in this design.
1. Is the rotating assembly completely different or could you use a 351 crank and rods with the Boss 351 pistons?
2. Is there any other modifications that need to be made? Other then different pushrods and a different set of headers and intake?
3. Is the time cover the same as a 351W?
Thank you everybody for your time and I would greatly appreciate any comments or suggestions. Thank you.
Old Nov 28, 2007 | 09:54 PM
my77stang's Avatar
my77stang
Default RE: Boss 351 Rotating Assembly
patriot aluminum heads, 895.00 - more power than the Cleve / BOSS heads and its a simplified installation
Old Nov 28, 2007 | 09:55 PM
mustang289's Avatar
mustang289
I'm sorry in the first question I meant to say could you use a 351 Windsor crank and 351 Windsor Rods. Thanky ou
Old Nov 28, 2007 | 10:02 PM
69mach1377's Avatar
69mach1377
ORIGINAL: mustang289
If you are talking about a clevor...to start with;
1. You can use theW rotating assembly, but calculate the CR
2. Drill holes in the block to match water path of theheads
3. yes
Old Nov 28, 2007 | 10:09 PM
mustang289's Avatar
mustang289
Thanks 69 Mach
When you say you can use the W rotation assembly, are you including the W pistons. Is it possible to dish the W pistons to work with the C heads
Also, I would like to call my self mechanically inclined, How difficult is drilling the block to match the water jacket?
Old Nov 29, 2007 | 12:35 AM
andrewmp6's Avatar
andrewmp6
Heres a link on where to drill the holes in the block and heads http://www.themustangshop.com/clevor.cfm
Old Nov 29, 2007 | 04:40 AM
67mustang302's Avatar
67mustang302
Build the 351W and put Edelbrock's new 51309 heads on it. It'll make tons more power than it would if you built a Clevor using stock heads.
Old Nov 29, 2007 | 07:39 PM
69mach1377's Avatar
69mach1377
Thanks 69 Mach
Yes, mine are forged flat tops with a .050" dish at zerodeck height. Be sure to measure valve clearance during assy.
Drilling the holes with a hand drill is easy.
Old Nov 29, 2007 | 07:49 PM
JBradley500's Avatar
JBradley500
Use CHI heads if you are going to use Cleveland heads at all...they are top of the line
PaulH2
20
Jan 31, 2016 09:48 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
UrS4
Sep 30, 2015 10:13 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
