OIL LEAK
Old Dec 1, 2007 | 03:28 PM
boogerschnot's Avatar
boogerschnot
Default OIL LEAK
ITs like it never ends.. First I built the motor, got it running and my dampner seal was folded so, it was throwing oil everywhere,, So I changed it out,, now the thing is running great,, still needs carb tuned, but its leaking from where the timing cover meets the oil pan,, IS that the front main seal? Soo.. Its leaking, but not terribly,, but still,, its leaking. I think Im going to just run it the way it is for a bit until Im scheduled for the next oil change, and then drop the pan then for a new gasket install.. I tried to just tighten the pan to the block/timing cover, but that didnt do it..
If I were to let her cool, dry it up and then put a bead of RTV on the outside of the cover, do you think that might seal it up?
Oh,, and the exhaust install went great,, 2.5 flowmasters with an H pipe out of the back,, and it actually sounds like a car now instead of a beast plane flying down the highway..
Old Dec 1, 2007 | 04:11 PM
rst08tierney's Avatar
rst08tierney
Default RE: OIL LEAK
IMO its the main seal, but i like your idea of letting it run for awhile. When I dropped my pan, and replaced the gasket it leaked for 3 days after and then it stoped. Unfortunately old cars leak,if its not one leak its always another.
Old Dec 1, 2007 | 04:45 PM
Colorado_Mustang's Avatar
Colorado_Mustang
The main seal is the one in the timing cover and seals the crank. The other is just the pan gasket.
You'll need to clean the area to see exactly where the oil is coming from. Likely, it's the corners where the rubber end piece and cork come together. Make sure to add a dab of silicone here to prevent leaks. It's possible that sealing the area with silicone on the outside of the pan will work.
Old Dec 1, 2007 | 05:42 PM
boogerschnot
Yea, I made sure to use the silicone when i installed it, I dont think its the crank seal thats leaking,, I really think its the pan gasket.. It sucks either way,, getting oil all over my freshly painted engine bay..
Old Dec 1, 2007 | 05:53 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
make sure to get a 1 piece oil pan gasket when you go to fix it
Old Dec 1, 2007 | 05:54 PM
Starfury's Avatar
Starfury
Just because it's an old engine doesn't mean it has to leak:-| Could be a pinched gasket, overtorqued bolt, or just a spot that you missed with RTV. I think if you redo the pan gasket it'll be fine.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
