c-6 trans leak
Old Dec 4, 2007 | 11:23 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default c-6 trans leak
I got a friend who has a 67 cougar with a 390 and c-6 tranny in it and there is a leak where the PRNDL switch is located it is coming out from behind there and I know the shaft is sealed by a seal.........anyone ever replaced this seal?? if so...what is required?? do you have to drop the pan and valve body????? or is it an external seal/o-ring that you replace??
Old Dec 4, 2007 | 01:27 PM
TexasAxMan's Avatar
TexasAxMan
Default RE: c-6 trans leak
You definitely have to drop the pan. I think then you just unbolt the selector shaft, disconnect the linkage, and remove the shaft. Installation is the reverse of removal.
Old Dec 4, 2007 | 02:56 PM
mjr46's Avatar
mjr46
ORIGINAL: TexasAxMan
well your half correct the only other thing I had to do was drop the valve body assemley...it wasn't all that bad....you can't get a wrench up there as the valve body interferes with the wrench position but hey it's apart now....now I just have to find a selector shaft seal....any ideas where to find that and the accumulator cover gasket also???
Old Dec 4, 2007 | 04:16 PM
TexasAxMan's Avatar
TexasAxMan
I wasn't sure about the valve body, sorry. I have to do this soon as my new tranny (rebuilt C-4) has the wrong linkages. I guess I'll install a shift kit while I'm at it.
Check with a local transmission shop, they will either have it or should be able to refer you to someone that can supply it.
jerrytubes
Oct 23, 2015 12:11 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
