weird electrical issue
Old Dec 9, 2007 | 07:04 PM
darksqueegie's Avatar
darksqueegie
Default weird electrical issue
For some reason in my 66, everytime i turn the wheel to the right my entire electrical system shorts out for a second. Lights, radio, everything, even the engine quits for a sec then comes back to life. Anyone got any ideas?
Old Dec 9, 2007 | 07:09 PM
cmanf's Avatar
cmanf
Default RE: weird electrical issue
Check you battery cables sounds like the neg is loose. Check @ the starter too.
Or your connection to the main under-hood harness it is on the drivers side by the master cylinder.
Something is loose if it was shorting out I think you would have blown fuses.
Old Dec 9, 2007 | 07:15 PM
JamesW's Avatar
JamesW
Sounds like you've got a bad turn signal/horn unit in your steering column.
Old Dec 9, 2007 | 07:22 PM
cmanf's Avatar
cmanf
Good point I smelled smoke when mine went out. I didnt loose everything just the signal light froze up a lil smoke and a burnt fuse.
More to learn everyday Thanks James
Old Dec 9, 2007 | 07:56 PM
az1966's Avatar
az1966
turn signal switch, is best,,,,turning the steering wheel and things happen? ! wire grinding some where at the top of the column/turn signal switch
Old Dec 9, 2007 | 08:05 PM
JamesW's Avatar
JamesW
I'd take care of that pretty quick. There's a full 12V always hot wire running up the column to the horn. You may want to unhook your battery till you can get it fixed.
Old Dec 9, 2007 | 09:11 PM
tarafied1's Avatar
tarafied1
James nailed it I think! I had the same issue on my 67. The horn insulator in the steering wheel was broke and let the horn ring short out. I saw sparks at night when I turned the wheel.
Old Dec 10, 2007 | 06:24 AM
67 evil eleanor's Avatar
67 evil eleanor
Buy a replacment with the wires that run down the column. Make sure you mark the wires if you have to use the old plug. It can be either in the switch or the wires that run down the column. Like James said, it needs repaired right away.
Old Dec 10, 2007 | 10:34 AM
kalli's Avatar
kalli
i'd unmount the horn ring, get rid of the c0ontacts in there and put it back together. if the issue disappears you know what to look for
kalli
Old Dec 10, 2007 | 08:27 PM
tarafied1's Avatar
tarafied1
ORIGINAL: kalli
kalli
+1
