exhaust leak somewhere
Mach I Section Moderator
looks like i need to check all my bolts and valves....ill do the valves this weekend,
the ticking goes away when i get to a certian RPM ...valves?
not sure, but you can ask someone to hold up an old rug against the exhaust tip to try and block those fumes coming out.
This builds up pressure in the exhaust system and it is much easier to find if you have a leak somewhere (as all the additional pressure is trying to get out there then).
if you have crossflow pipes you'll have to block both exhausts. Don't use any kind of plug, don't stick anything into the exhaust, just try to hold it closed if that makes any sense)
Kalli
Kalli
yeah, it does....i just have stright pipes so nothing crossed here....the more i think about it the more it sound like the valves need adjusting.
whats this positive stop stuff?
trashxtrash
Sep 20, 2015 10:49 PM
Sep 10, 2015 08:39 PM
