347 stroker dilema
Old Mar 15, 2005 | 08:07 PM
my66stang's Avatar
my66stang
Default 347 stroker dilema
I have a 66 mustang with a 347 stroker. I've been building the engine for a year now and im running into difficulties. Almost everything on the engine is brand new, so heres my problem....when i take my car for a drive and come to a stop it acts like it wants to stall and when the engine is fully warmed up it will. I thought i might have high vacuum levels so i've been tweaking with the carb for the past month with only increase in torque. This is wat is done to it...It was a 289 stroked to a 347, ported stock heads, 512 lift 230 duration comp cam, edelbrock 1405 carb, edelbrock duel plane high raise intake manifold, and a holley hipo fuel pump, theres lots of other stuff done also. I am running a 2 inch exhuast, but only temporarly untill this weekend and then side exhuast. Does ne body know why im stalling???
Old Mar 16, 2005 | 12:37 AM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
Default RE: 347 stroker dilema
is your carb good ..and what size of converter do you have in the tranny?
Old Mar 16, 2005 | 01:35 AM
my66stang's Avatar
my66stang
Its a brand new carb, ived changed just about everything in the carb, jets, metering rods, step up springs...Its not an automatic, four speed with a zoom clutch
Old Mar 20, 2005 | 03:56 AM
83GT306's Avatar
83GT306
Sounds like high float levels... runs good cold because it needs more fuel, then dies when the engine warms up.
Check your fuel pressure and/or install a pressure regulator if the pump has too much output.
Get rid of that 600 cfm Edelbrock carb for a 700-750 Holley dbl. pmpr. It'll never run right until you do.
Did you say 2" exhaust? You might want to upgrade that to 2.5" duals.
Check for vacuum leaks and stuff around the intake ports and carb ports, vacuum lines etc...
Old Mar 20, 2005 | 01:51 PM
my66stang's Avatar
my66stang
will do, Yeah i thought i might have too much pressure to the carb but i didnt think it would cause a problem. Thanks for the help.
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
Darrens07GT
Aug 10, 2015 03:59 PM
