performance brake fluid/pads.
Old Dec 24, 2007 | 03:32 AM
67mustang302's Avatar
67mustang302
Default RE: performance brake fluid/pads.
I'm running Wilwood Discs with the full metallic E pads. I use EXP 600/equivalant for brake fluid, but the 570 works fine too. The 600 has a muchhigher wetboiling point though.If you're boiling that stuff then your brakes are on fire.
Old Dec 24, 2007 | 05:02 PM
Reverb's Avatar
Reverb
The best brake fluid you can get is ATE Super Blue DOT 4 - it exceeds the standards for DOT 5.1 and is blue in color so you can tell when all the old fluid has gone completely. It also comes in amber - you alternate on changes
http://www.tirerack.com/brakes/ate/a...blue_fluid.jsp
I always used EBC Green Stuff pads back home, but I hear excellent reviews on the Yellow Stuff pads. Not sure if they are available for your application.
Old Dec 24, 2007 | 10:34 PM
project.65's Avatar
project.65
Sounds like most of you are saying,flush my system out,addDOT5 with performance pads will help my braking performance.
I currently have DOT3 with semi-ceramic pads.
Now I dont know what fluid to get, so many options[&:]...
Old Dec 24, 2007 | 11:42 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
baer recommends no silicone based fluid for street and ocassional track use http://www.baer.com/technical/brakin...kebleeding.php
Old Dec 25, 2007 | 12:55 AM
67mustang302
Silicone or not depends on what type of seals the manufacturer of the master cylinder used. Wilwood for example states expressly NOT to use silicon based fluids with their m/c's for risk of seal failure. A lot of older Corvettes on the other hand specify a silicon based fluid from the factory. If you have any performance/chassis shops in your area that have any brains, you should be able to get a Wilwood 570 or equivalant fluid, they'll usually have a 570 and a 600 in stock from a few different manufacturers.
How big are your brakes, and what tires do you have? Increasing braking with bad suspension/tires won't help much. Or better pads on scrawny rotors will overheat and wear out faster, or possibly fade if they get hot enough.
Old Dec 26, 2007 | 03:59 PM
66 Restomod's Avatar
66 Restomod
[/size]The Valvoline Synpower fluid exceeds DOT3 and DOT4 specs, but doesn't state that it's DOT5:[/size]
http://www.valvoline.com/pages/products/product_detail.asp?product=51
[blockquote]
"Valvoline's Synpower High Performance Brake Fluid is recommended for all ABS, drum or disc brake systems which specify either DOT 3 or DOT 4 brake fluid."[/size][/blockquote]
[size=2]I filled my Baer system with it a few months ago, but the car's been getting painted so no real world experiences, butthis fluid isgenerally recommended as far as I have seen.
Galactic
Apr 29, 2019 02:56 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
