Engine Swap
Old Dec 24, 2007 | 02:26 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Engine Swap
I have found a 302 carbed that is in a 73, 74 Torino. I was wondering if my tranny would fit the engine. I have a 67 with a 3-speed.
Old Dec 24, 2007 | 02:50 PM
dirtydave289's Avatar
dirtydave289
Default RE: Engine Swap
I think if you have a 6 bolt bellhousing then you're all set
Old Dec 24, 2007 | 04:11 PM
Starfury's Avatar
Starfury
You do realize there's a lot more to a V8 swap than just the engine, right?
Old Dec 24, 2007 | 05:12 PM
1slow67's Avatar
1slow67
ROTM Moderator
Like what? All im doing is the engine. Everything else is going to be the same.
Old Dec 24, 2007 | 05:14 PM
Mustangdemon67's Avatar
Mustangdemon67
you going to put 5 lug axles in there? going to keep the same suspension? i think you might need a different flywheel
Old Dec 24, 2007 | 08:55 PM
andrewmp6's Avatar
andrewmp6
Mustangdemon you cant just swap axles you need a whole rear end 8inch atleast front hubs brakes front springs motor mounts motor mount brackets radiator some wiring and plumbing.The reason is the inline 6 cars have lighter front springs and small drum brakes so stuffing a small block in it will make it handle worse and stop slower thats why you swap everything i listed for safety.
Old Dec 25, 2007 | 03:06 AM
Mustangdemon67
i know, i guess i should have specified housing third member n all instead of just sayin axles........ my bad
Old Dec 25, 2007 | 06:42 PM
JamesW's Avatar
JamesW
Jake,
1974 was probably THE worst year for the 302 motor. The automakers were fighting emissions regulations and high gas prices, and the motors of that era (74-78) were very poor performers.
Recommend you find yourself a nice 89-92 roller 5.0 and put in there. It'll cost you about the same.
Old Dec 25, 2007 | 07:07 PM
Blackms3's Avatar
Blackms3
You don't HAVE to do anything but the motor.... I ran the 6 cyl drivetrain for months before I did the 5-lug conversion..... It's definitely preferred, but you don't HAVE to do it...
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
