sme quick help....
Old Dec 24, 2007 | 10:17 PM
project.65's Avatar
project.65
Default sme quick help....
I will be going to look at a 9" rear tomorrow and just need some tips on how to tell if its really a 9". Is there any way to tell, just by looks??
-thanks.
Old Dec 24, 2007 | 10:41 PM
john721's Avatar
john721
Default RE: sme quick help....
The carrier section is bolted to the housing, just like the 8" rear, only with a 9", you can't use a socket on the bottom nuts, you have to use a wrench to remove them. (The casting won't let you get a socket on them). Sounds confusing, but when you see it, it will hit you...
Old Dec 24, 2007 | 10:46 PM
baddog671's Avatar
baddog671
The housing should be 52.25" wide from flange to flange for your model and axle face to axle face is 57.25". Rounded backside
If it is a 67-70 then its 54.25" and 59.25". "Hump" backside with 2 dimples
Old Dec 24, 2007 | 11:02 PM
superdavid's Avatar
superdavid
John721 has got it right. Those bottom bolts are a real pain.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
